GodDAC - 192/24 USB DAC
Hello BizonGod,
This is a very interesting project ! I actually wanted to do something similar but it seems that you did most of the work already 🙂
Is this project open source, i.e. are the schematics and PCB layout openly available ?
Another question is about the analog input / output: do you use op. amps. before the ADC / after the DAC ? If so, which op. amps. ?
How many layers has the PCB ?
I'd like to buy one of the assembled boards from you but please do not solder on the op. amps. since I might want to use some others. Can you deliver a board like that ? I mean, can you send the board and the op. amps. in the same packet but the op. amps. not soldered on the board ?
Of course, no problem, You will get one without opAmps 😉
Do I have to solder other components of LPF around DAC/ADC?
Resistors and caps are 0603 size, tantalum decoupling caps are
A size, of course there are no ceramic/tantalum/electrolytic caps in
audio path.
For all 8 pcs I ordered 24 pcs of OPA2134 and 8 pcs MC33078
for dual opAmp (each device needs 4 pcs) and 6 pcs of LME49710 of
single opAmp (each device needs 2 pcs).
PCB is four layer mainly due to BGA package of CPU, also ground and power
planes are separated into analog and digital parts. Of course PCB is gold plated 😉
I have plans to make it open source (code, schematics, gerber files for PCB),
but I need confirmation from programmers that they will take part in software.
Code project web page started :
http://code.google.com/p/goddac/
Soon I will place there all usefull examples to mix up 😉
Board is powered by USB. OpAms by DCDC converter with CLC filter including
tantalum caps and large FC series electrolytic one. Every one chip on board is
well decoupled (each power pin of analog part has own 100n + 10uF or 47uF).
Of course, you can bypass DCDC and take power for analog part from external power
supply (-+10V, +5V)
goddac - Project Hosting on Google Code
I just came across your project while researching async USB audio. Very interesting.
I'm a long-time C and x86 asm programmer and reverse-engineer, almost exclusively in the security field (binary analysis, stack/heap overflows, shellcode development etc) although recently I've been working on some ARM reverse engineering projects on the iPad, particularly in the field of bypassing/disabling certain security mechanisms. I can't really say much more about that due to NDA issues.
Anyway, I'm game for getting involved in this project. Let me know what you need and I'll let you know if I can help. It sounds like a lot of fun 🙂
Carl
