This question can have multiple titles?
Where can you obtain the now famous Aleph 5 MF30 heatsink?
Is there a reasonable facsimile out there?
Other heatsinks used?
Suggextions, links, part no.'s?
Dan
Dan
I don't know if those are the sinks you were asking about, but they look pretty close to the ones used originally on Aleph 0 and subsequent Alephs. Later different sinks were used, but I always thought that those looked better.😉
I found them in an old Ahamtor catalog. The phone listed in catalog is 1-800-367-7588. Looks like another Diyaudio mystery solved.😉
Actually, I was trying to duplicate Mark Finnis's (http://www.users.bigpond.net.au/mefinnis/passlabs/aleph5_construction.htm) Aleph 5. That's why I'm pursuing the exact same heatsinks that he used. If you look at his site you'll see that the heat sink's he used you'll see they have a unique feature. They have two bars perpendicular to the base where the transistors attach. Here's a pic:
Peter Daniel said:Check the Trading Post, someone in States was selling them.
rlim was selling some as a one time deal in the trading post (I got a few), but the deal's over. He might have some insight on getting them shipped from Aus however.
Are these sinks (one of them) enough for an Aleph5 (one channel)? I know Mark Finnis built a stereo A5 with a pair, but he never answered any of the questions regarding temperature in another thread. They seem about the same size as the sinks on the Aleph 60 (actually a little shorter), but the 60 was a monoblock if I'm not mistaken. Makes me worry. I'll probably proceed with an Aleph 30 until then (or something scaled in between).
They are nice sinks (appearance anyway.)
Rob
I believe MFinnis mentioned in his article that these sinks were "right at the limit" or words to that effect when used one per channel on an Aleph 5.
I will be using 3 of them on my Aleph 5, ThingyNess has the vendor info. for aquiring them.
I can tell you though that they are beautiful sinks and an excellent value.
Tony D.
Tony D.
Peter Daniel - I'm from Europe - so the phone number doesn't help me much - but I'm very interested about that heatsinks - the cube design is my favourite since I first some one of the Aleph's ... Any sugestions how to get some more infos about that heatsinks - particullary the price, availability, ...
Thanks in advance
Thanks in advance
Peter! Because you are both a fellow canuck and a fellow Torontonian I was hoping you could point me in the direction of some heatsink suppliers in our area.
Dan
Dan
I believe the heatsink is produced by Conrad Engineering. You should be able to order it through Printed Electronics, they sell internationally. Sales Enquiries: pcbs@alphalink.com.au.
Hope that helps.
Pete
Hope that helps.
Pete
dantwomey said:Peter! Because you are both a fellow canuck and a fellow Torontonian I was hoping you could point me in the direction of some heatsink suppliers in our area.
Dan
Your best bet is http://www.r-theta.com/indexf.html
They are in Mississauga.
Stabist said:Peter Daniel - I'm from Europe - so the phone number doesn't help me much - but I'm very interested about that heatsinks - the cube design is my favourite since I first some one of the Aleph's ... Any sugestions how to get some more infos about that heatsinks - particullary the price, availability, ...
Thanks in advance
I did web search and nothing came out under Ahamtor name. I don't even know if they still exist. Those company was recommended to me years ago by Nelson Pass. Maybe he would know their current contact.
The old address was: 27901 Front Street, Temecula, CA 92590
I don't recommend AhamTor. They were very difficult to
deal with and I had severe quality issues. After the first
couple of batches of Aleph 0, I got my own die and went
elsewhere. You will note that the Alephs later had two
sinks to form that corner.
Another question about original Aleph heatsinsks, if I may: the back, with the sink with all plugs and all - did the heat flow compensate through all other heatsinsk or were those transistors a bit warmer???
There was a question like that already, by fcel, I believe.😉 No compensation was done, and the mosfets run a bit warmer.😉
Um Hello? This heatsink, the Flanged MF30- 2F-151.5 is manufactured by Conrad Engineering according to my data sheet. You should be able to purchase through Aspen Amplifiers, sorry but it seems Hugh Deans details have changed to those I gave previously. Contact him through http://www.aksaonline.com
Pete
Pete
Sorry about that chaps ....... only because I must have been busy and not seen the question.Originally posted by relder Are these sinks (one of them) enough for an Aleph5 (one channel)? I know Mark Finnis built a stereo A5 with a pair, but he never answered any of the questions regarding temperature in another thread.
The Conrad sinks as above are slightly under what is really required for a stereo version. After 4 hrs of constant music the flange between the FETs is at 70C ..... which is just a little warmer than I would like. It works, you can do it, but I have to accept that the result is sub-optimal.
The easy answer is to use 4x the 200mm deep versions of the same heatsink. this will make the amp 400mm deep cf mine which is 300 deep, but the additional sink will be just about perfect 🙂
Contact details for Conrad are on my website. they now have an e-mail address which I don't have here but will post tomorrow sometime.
cheers,
mark
The contact e-mail for Conrad is conrad.aus@bigpond.com - I got this from rlim, and addressed the e-mail to Julian Wales.
The price they quoted for 2 of those heatsinks + FedEx air freight shipping seemed reasonable, but not as nice as the price from that group purchase. "A major component of the price is the freight cost - there is a significant reduction per heatsink with larger volumes (esp. 25 kg +)." Also, the fact that I'm on the east coast USA doesn't help. 😛
mefinnis:
When you say the result is sub-optimal with 2 heatsinks for the stereo Aleph 5, do you think sound quality is comprimised?
mefinnis:
My plan is to use 3 of the MF30's, one on each side and one at the back of the Aleph 5 with 4 devices per sink.
I had thought of using 4 sinks but I had the feeling it would not be symetrical with 3 devices per sink.
Tony D.
Tony D.
No, I do not believe so, but only the likes of Nelson could really answer this, he has possibly looked at sonic performance over the thermal range for these devices - given he uses them extensively.Possum said:When you say the result is sub-optimal with 2 heatsinks for the stereo Aleph 5, do you think sound quality is comprimised?
We are still well within the thermal rating of the device (up to 150C junction temp), the only real problem is children burning themselves, setting fire to the curtains and burning down the house, and the one real problem of a reduced lifespan for the FETs.
Nelson uses a very conservative operating environment for his devices (1) because it is good engineering, and (2) because he charges serious money for his products and people (read customers) can get really "funny" with random device failures ..... so he engineers to absolutely minimise these.
We are in the DIY world and we can do whatever we want, understanding the consequences. At 70C heatsink probably equates to 110-120C junction temp in a worst case scenario.
The thermal rating of these sinks is 0.25C/W. If we look at 2x the 200mm version (rated at 0.38) we get 0.19C/W, which should get our sink temp down to the high 50's C ...... hence this is what I would recommend.
You most certainly can build exactly as I have, knowing that you just gonna be a little hot
cheers,
mark
- Getting the famous MF30 heatsink?
