Geddes Bandpass Subs and the Multi-sub approach
The easy answer is
I appreciate the easy answer.😀
I like IB for the easiness of adding multiple drivers. However, I don't like the idea of pressuring the whole attic.
With 4th order BP, I could put multiple boxes in the attic and have ports extending through the ceiling into my room. The bad part is that I don't know much and haven't gotten any good modeling for it.
Most of my friends live in 2 stories houses. If there are boxes the could fit above the ceilings, either in the attic or below the 2nd floor, they might adapt the idea of multiple subs. If I tell them to buy multiple floor subs, their wife would ban me.😉
Dr. Geddes, is it accurate to say though that only a 4th order bandpass and a sealed sub woofer is acting as a monopole bass source. That a ported subwoofer and a 6th order or 8th order, etc. would also act as a dipole radiator below resonance?
Correct
An IB could do that as well I think.
Correct as well, but true IB is pretty rare and hard to do.
Yes, I agree that IB poses some real problems with noise control - the backside sound being noise to anyone else. The bandpass solves this problem and protects the driver. The ports can be quite large - which is good - when they are not in the room.
SPEAK (on my website) is now free and it does a really good job of modeling bandpass enclosures.
So, I thought an interesting alternative to an IB with VLF response would be a large bandpass box located in the "external" space (no need to worry about how big the box is) having an external port (for the front chamber) that comes up to floor level. Just put an 8x8" grill over that and you are good to go... high output down to 10Hz or so (depending on the driver, box, and where you put it). Only problem is that you can't move it - so you have to be pretty sure that you have selected a good location beforehand (check it out with another conventional sub at the same location in the room where the grill will be located to make sure you can get a flat response with the sub there).
I guess the other complication might be the port resonance for the large (6" dia) port required. Perhaps four narrower ones grouped together (so the sound can exit from the same area) would avoid that.
I find the claim that a vented box cannot pressurize a room at low frequencies to be ridiculous. How does it make sound, if it does not pressurize the room? Room pressurization occurs when the wavelength is twice the longest dimension of the room or more. The pressures inside a reflex enclosure are several orders of magnitude greater than the pressures in the listening space. If you are talking about infrasound below vent tuning, a reflex box does not become a dipole unless the port is directly opposite the woofer. Otherwise it forms an acoustic short circuit, not a dipole, since the term 'dipole' describes a specific radiation characteristic. But a sealed box (or 4th-order bandpass) cannot pressurize a listening space in any meaningful way at frequencies below 1/2 Fc, either, without EQ or modal reinforcement from the room itself.
I'm sure you've encountered this opposition before, so please educate this unwashed mass. How does a small room interfere with the reflex action of a reflex enclosure, inhibiting its ability to pressurize the room within its passband? (I can think of a simple way to test this, and it involves an impedance sweep.)
I believe what was specifically stated was that it couldn't pressurize the room below it's resonant frequency, i.e. the pass band. The reason given was because it's effectively a dipole source at that point, and that only monopoles can pressurize a room. I did not interpret this to be a blanket statement that a vented box is always a dipole, nor that it couldn't pressurize a room above the tuning. It's my understanding that it operates as a monopole above the tuning frequency and thus can "pressurize" a room in that range, but below that range it can not.
There is widespread misunderstanding of "room gain" or "pressurisation". For example, it is usually plotted as a curve but in fact is constant, or a "straight line".
Go here for an explanation:
http://www.diyaudio.com/forums/subwoofers/62267-modeling-room-gain.html#post2072634
For a sealed speaker, the "room gain" calculation is straightforward - measure the volume displaced by the cone, measure the room volume, calculate the "pressurisation" SPL.
For a vented enclosure, the air volume from the port has to be added to the air volume displaced by the cone. (Or, below resonance, subtracted from the cone displacement.)
As for the effect of room size on the performance of a vented system, you can model the room as an enclosure attached to the "front" (combined port and driver) of the system. You'll find that any sane size of room is going to be so much larger than the system volumes that the effect on the system tuning will be minimal.
So as a practical rule of thumb, a vented system will "pressurise" a room, but only down to the system's resonant frequency. More specifically:
Any system topology that has one side of the driver sealed off from the room (sealed, 4th order bandpass, infinite baffle) will exhibit "room gain" at frequencies well below the system LF resonance.
Any system topoloy that allows both sides of the driver to couple to the room (vented / reflex, 6th order bandpass, open baffle / dipole) will not exhibit significant "room gain" at frequencies well below the system LF resonance.
The one factor that is missing in the discussion is the room "leak". Room gain assume a zero leak of pressure or at least a leak that is slower and less than the level of the sound. This is seldom the case, since all rooms leak (or we would suffocate). This leak then becomes the dominate factor in the SPL as the frequency goes to DC.
True, most rooms are full of holes. Personally, I assume no room gain and treat any that occurs as a bonus - just roll off the bass drive to suit.
But a well designed home theatre / dedicated listening room shouldn't leak very much. (Concrete slab floor, cinder block or brick walls, prestressed concrete beam ceiling, solid doors with gaskets, HVAC ducts long enough to tune to infrasonic frequencies.)
Even without special construction techniques, room gain should still be taken into consideration in many cases. For example, small rooms usually have fewer openings - often, just one door and a window. In the UK, the room will often have a small window, brick walls and heavy timbered floor and ceiling (the ceiling being the floor of a second storey.) And for a given driver volume displacement, small rooms exhibit more room gain than larger rooms. I believe that room gain is a significant factor in the popularity of bookshelf sized speakers in the UK.
Yes construction and size make a big difference. My home theater is as sealed as I believe possible and I don't find much room gain. Theye is a huge resonance at about 20 Hz - the first longitudinal mode and below that it drops like a stone. Don't see much there at all.
We saw room gain in spades in cars however.
Something that I think was already mentioned, but I've also thought about is creating a sort of hybrid 4th order bandpass and infinite baffle. The way I envisioned this was that the rear "sealed" chamber would be the very large open area the back wave fires into. The attic, the basement, etc. The front tuned chamber would then be designed specifically with a tuning in mind. I would imagine that these chambers have a tuning to them anyway, but that people rarely take it into account. It would not be for broad band purposes, it would only be for the ultra low frequency. Also, it would likely only work for people who have a room the back wave can fire into and not disturb others. I'd imagine an attic could be possible, and a basement only if the basement wasn't serving other purposes, and assuming the basement was sealed off from the upstairs well enough to keep the bass from traveling back into other rooms.
My thinking as to why this is advantageous over other modes of ULF reproduction is that it has the same benefits of lower distortion in the passband, with a much lower passband than is typically possible in a room. Bandpass subs capable of 115+db's below 50hz tend to be huge, so being able to move this into a space outside the room would seem to be a good thing. Whenever I've modeled a ULF bandpass capable of the output and efficiency I want, i end up with rear sealed chambers in excess of 10 cubic feet, and a front chamber often in the 5-10 cubic foot range. This means a 20+ cubic feet is perfectly reasonable, which is just too big for me, and probably most people.
Another option I thought about was a Line Array subwoofer that goes floor to ceiling, sealed, fed with excessive amounts of power, and eqed to have bass down into the very low range. It's still a pretty inefficient option, unlike the above mentioned option, but I would think would achieve the desired results very well. I think this would work best with two of these units, one in each front corner, and the the BB subs distributed around the room as before.
So I was having trouble getting the bandpass subs balanced out in my room. I tried something counter-intuitive that actually helped a lot. The problem was that around their pass band and below the response was rising too much, but lowering their level caused too much loss a the top of their pass band.
I applied a shelf filter and first order high pass filter. The highpass had a corner at 55hz and the shelf started a bit higher, around 70hz. Combined these two seemed to really flatten the response. Interesting the filters that will fix room modes. I was trying to use tons of parametric eq's to no avail.
Sorry for digging out old thread, but it seems to me more appropriate than other which shifted out of theme.
I'm living in old multi-storey block of flats with thick brick walls and relatively thin brick partitions (7''). Before I moved in I had to made nearly complete reconstruction. I was short in time and money. Nevertheless when I had heard neighbour's TV-set I let to make a double-layered drywall with constrained layer made of glue (as per E.G.), but particularly as a sound insulation and one single layered on the perpendicular wall. (It turned out later, that situation was not so bad, because neighbour is deaf as a gunnery horse and TV-set was on very loud) Unfortunately the workers made it stiffer than I had asked.
I have made several quick spatial measurements of my room (using Nathan in the corner) and then identified modes and their bandwidths. BW of modes vary around 5-6Hz (below 50Hz) and around 9Hz (below 100Hz). So the absorbtion coefficient is 30% or 40% respectively. There are 9 cases where the modal BW is not more than twice the modal spacing. It seems to be a problem to me, which is not going to be eliminated even with multi-sub. (No attempts already made)
What are your experiences? Does my damping work at all? What is your room LF damping?
While I hate to speak for Dr. Geddes, I think I know the answer for him, and myself. His LF dampening consists of the CLD walls over an air pocket, created by the studs. I don't know if there is insulation in the cavities, but I would assume so. Essentially a wall can be looked at as a giant LF energy converter. If the wall has a resonance, which it does, then when that resonance is excited, the energy taken to excite it will converted from vibrational energy to heat. The efficiency of this is largely dictated by size I believe. This is why in my opinion (and many others I believe) many bass traps are a waste of money, they lack the size to be effective at such low frequencies.
My own LF dampening is nill right now. In my old place I had setup some DIY bass traps which were essentially the same CLD type. I had an 8" cavity, a large CLD surface, and fill inside. The resonance of the panel dictated the center frequency of the trap. The fill and panel dampening changed the Q. These are as effective as it can get, but to equal was the wall can do in the first place, they have to be as big as the wall, and at that point, why not just turn the wall into the bass trap.
I think if your CLD is mounted directly to the Brick with no air pocket, it won't be offering much of any LF dampening. If thats the case, then you would need to add studs to space the panel from the wall, it should be spaced as much as is reasonable, I would suggest 6-8 inches. The panel cavity would benefit from insulation of some sort, with some being a bit better at lf's due to their higher mass.
I think there is benefit to multiple subs for you too. I'm not sure I understand why you believe they won't help. I'm not sure I understand why the BW or Q of the modes matters in terms of the effectiveness of the multisub approach.
Multiple subs will always be a benifit, but so will good LF damping. Sounds like they made the CLD wall too stiff. It really has to be quite flimsy to work right - think or a hanging sheet of cloth - very limp. Most often that I have seen people try this technique they make it far too stiff and it kills the effect.
Given that its made of Drywall, won't it have a certain stiffness you can't avoid? What is the thickness of the pieces you laminate together? I figured you used 1/2" or 5/8" gypsum board, with your urethane mixture as the dampening layer between them. How thick do you try and get the urethane layer? Do you mix anything with the Urethane to improve the dampening properties?
What about the attachment to the walls? Is it the typical screws or nails method, do you use more or less of them, decoupling of any sort, etc? I recall you said you used resiliant channel or RSIC or something along those lines?
I use 1/2" drywall and historically used Liquid nails. My polyurethene mixture would work better, but I have not used that on a wall structure. the Liquid Nails (for Subfloors) is spread about 1/4" with a flooring trowl. I attach the first layer to RC1 resilient channel, which is attached to the studs, then the second layer is just glued on the first. You have to hold the layers together with screws until set, then just remove the screws.
Ah makes sense.
I thought Liquid nails dried hard? Is the subfloor formula stay softer? My experience with liquid nails, such as using it to adhere drywall to firewalls has been that it dries out to a hard as rock material.
While quite expensive even compared to the urethane mixture you use, Green Glue is purported to offer the best performance. They have a lot of good independent testing to support it, but I suspect you could come close to equaling the performance with urethane and some filler. The MSDS indicates its Urethane and some stabilizers, but MSDS doesn't give precise formula descriptions. I'm guessing there are additives to improve the dampening. Plus, not all urethane is identical, different formulas. I've wondered about using the soft High density urethane foams as a possible material instead
