GC Heat
I am running my 3875 gainclone with a 4ohm load and i have a big heat sink made out of aluminium that measures about 7.5" x 3" x 1/8" full of fins on one side and they are about 2 inches long. My two chips are on the same heatsink and when the volume is at maximum it gets pretty hot. i don't know if it's normal...it's my first gainclone 🙂
should i buy another heatsink??? or its completly normal.... i searched the forums and they say that running the gainclone at 20v shoudn't dissipate any heat (mines runs at 20volt AC before rectifier and 28.5V DC after )
What about the sound? Good and loud or not as loud as you assumed?
At full volume it's normal if it runs warm/hot but take care of some points:
- are the chips isolated? If not are they isolated mounted?
- check inputs and outputs: may the gc oscillate (capacitors with wrong values)?
Some pics would help...
Michael
Michael
The sound is very good and loud
the chips are 3875TF (isolated)
and for the oscillation .... i bought a kit from Peter Daniel and installed everything that came in the kit so i guess they are the right values
But at low volume everything's alright i guess the heat is normal. and when i put a 8ohm load the temperature is even lower. i tought the 3875 couldn't handle 4ohm impedance
