Hi, hopefully not too late to request one pair of split boards and a pair of joined boards (total 4 boards) with ic soldered.
hopefully
Andy
hopefully
Andy
Hi
So can you please revise my order to for 1 pair (as opposed to 2 mono) boards, and with IC's include. I will install the IC's myself though.
BTW, I noticed an order before me for one board, I have a feeling he didn't understand these are mono boards.
Randy
Randy
Hi DUG,
would you include what xrk971's suggested mod which is originated from the EVM (330pf+10Rat the bootstrap cap)?
http://www.diyaudio.com/forums/class-d/237086-tpa3116d2-amp-383.html#post3990270
Hi DUG,
+1 on this, if it's not too late.
Hi DUG,
+1
Tho I think easy enough to retrofit with SMD components looking at the board layout.
hopefully
Andy
Done
Hi
Randy
Done.
Which post?
Hi DUG,
Done at post 60.
Look carefully on jpg in post 61, 73 or 108.
Just enough room for resistor on top and cap on bottom, both 0805.
Very interested to know the 1 pair (joined), with ICs installed, kit price.
More than 10 kits have been requested.
This is enough to start me getting a parts list together and calculating a cost.
I will probably have it by next Monday.
Later,
Doug
Done at post 60.
As this is PBTL and 2 bootstrap caps join each output leg (which is where the snubber components go to earth) maybe you only need 2 sets of snubber caps/resistors rather than 4?
Woops, messed up on replies...was in a hurry to not be late to where I needed to be tonight.
I was thinking AVCC isolation.
But the snubbers are also there and were there before AVCC isolation..
All good fun.
Boards were ordered last night and are in process.
Great stuff Dug.
Hi Dug,
Did you get my pm to you for 2 boards with IC soldered?
I am also considering a kit , awaiting the pricing.
thanks
kp93300
thanks
kp93300
Hi Dug,
thanks
kp93300
Last pm from you is:
14th June 2014, 11:44 PM
"Hi Dug
what parts are presoldered ??
thanks
kp93300 "
So glad you checked.
Did you want 1 pair (2 boards common ground plane) or 2 separate boards?
- Group Buys
- GB for TPA3116/8 PBTL bare pcb
