Is there a power supply board for this? or should I just wire one up P2P?
No, you will have to hard wire it.
I bought the caps directly from Audyn, and was hoping for the copper foil, but they were out of stock.
I cannot recommend them for the fact the leads are really only for loudspeakers, quite thick. We expanded the holes from the prototype to take larger wire, but I will don't think they would fit. If you do get some, cut the leads and solder on a copper lead wire to it.
At some point, I plan on swapping both one at a time out to see for improvements or not.
I have a teflon .047 and a 2.2uf SIO cap.
Package received today, everything seems OK. Thank you very much TB & Salas!
TB, any kit for Mezmerize B1 Buffer Preamp?
Hi MA_coule, yes I have some of those kits available, but still waiting for the 2SK170BL qauds before I can send them. I think I have 3 left. Tea
PM if you want further details.
Package reached this side of Planet Earth !!!
I have to thank and congratulate all people involved in this GB in any way.
As we say in my continent "you have put the glasses on" to many professionals..
Regards,
Marinos
Regards,
Marinos
Yes, I could see why the leads could be problematic. Trying to balance "Price to Performance", I'm thinking of trying the Jantzen Audio Superior Z-Cap for those two positions.I bought the caps directly from Audyn, and was hoping for the copper foil, but they were out of stock.
I got the package to - I haven't counted the pieces yet but will check it out during the weekend. Very nice PCB I must say. Thanks 🙂 !
BTW, no more boards for sale.
I believe Salas and I want to see some more builds being done before doing another GB. But it will happen.
I still have about 8 remaining packages to send out. Mostly from the people who volunteered for the delay. I am still waiting for 2SK170s for them, the biggest hardship in getting this GB. Once arrived and sorted, I will send out.
Of course I still offer to do partial shipment if you just need to solder something.
Can someone point me to the schematic?
I think it's in a PDF attached to the first post (TeaBag)
Matt
Anyone in the EU knowing where to buy these particular heathsinks? I have a bunch with the same size regarding footprint but they are a bit higher (51mm) and the fins seems to be a bit shorter. If I can't find the proposed ones I will test these and monitor the temperature.
Brgds
Brgds
- Group Buys
- GB for Salas Folded Simplistic Phono PCB
