cviller said:No, if I recall correctly he uses a quality 300VA donut for a stereo amp, but going bigger doesn't hurt and if you guys buy cheap toroids you'll have to go for bigger rating.
Not just bigger but better. I read somewhere to stay away from Antek.
Ed LaFontaine said:labjr,
I'd like to be better informed. If I had heard that with some background I probably would have done something else. Where's the beef?
At wendy's
Those cheap chinese transformers don't regulate well and run hot from what I've read. The good ones are supposed to give better sounding bass.
I haven't tested them myself but members with experience seem think you're better off with Plitron, Avel, etc.
labjr said:
At wendy's
Be sure not to confuse experience with old farts!
However I do agree that VA ratings are not always comparable between manufactures.
Here's one thread I read.
http://www.diyaudio.com/forums/showthread.php?threadid=101313
I don't want to build a nice amp and then be disappointed by the sound and not know it's because of inferior components.
Yeah, the Plitrons are more expensive than I'd like. But if Chinese ones use inferior materials then they are no bargain either.
Hmm, this seems pretty simple
You guys are in need of enough treafo's, to have them custom made, and even come out with a cheaper trafo in the end.
A smart guy would stick to a 500VA 2*18V 2*115V primaries.
When you cross the number of 10 trafo's, they almost throw them at you.
http://en.noratel.ezpublish.no/
Nice guys, easy to deal with, can make just about anything you could possibly imagine, fantastic quality, delivers on time, fair price, will deal with anybody
Magura
Magura
Magura said:Hmm, this seems pretty simple
I am not smart, but I will take your advice. I could use 3 trannies alone......
So if anyone else is interested in USA, speak up and maybe we should start a wiki for them. I would be willing to have them purchased and shipped to myself.
Besides, if they deal with anybody - they may actually put up with the likes of this crowd.
I will ask them for a qoute of 500va 115v 2 X 18 sec for 25 units.
If Magura uses them, they can't be too horrible.
I do use Anteks on F4, and it doesnt get hot or buzz. I am sure they are not awesome quality, but good for a many amp'd fellow such as myself.
Magura
Magura
Didn't they used to have a facility in USA at one time?
AFAIK they still do.
Magura
Re: custom transformer gb?
I am interested. I am asking Noratel for a qoute on 25+ or more 500va 115v 18+18v transformer.
I am also asking about R-Core toroids from Customer magnetics as well, for the same value. I have no idea if these are 'good' transformers, however, but the concept is sound.
I would say we should do a Wiki for the States anyways if we decide on a supplier. Piltron is also a consideration as well, what Papa uses.
caligula455 said:is anyone interested in organizing a group buy of custom transformers? with all these firstwatt board GBs going on right now and all the amps using the samee transformer it seems like there would be enough interest to bring the cost down.
I'll buy at least one for my project
I'd stick to a company with a good reputation. Not sure how much we'll save on a volume order with Plitron but worth a shot.
Do we really Need 500va? I guess you could check how much different the price is between 300-400-500va. Won't hurt to have a little bigger iron, but not absolutely neccessary.
Those of you in the 220VAC 50Hz land might consider the transformer Plitron has on closeout in their surplus area:
http://www.plitron.com/shopping/shopexd.asp?id=652
There was a previous group buy on those Plitrons so maybe they would do something again.
Plitron group buy
I used these for my F4's and they are really nice trafo's, though pricey.
Plitron group buy
Hi cviller,
I was reviewing your board against mine but shouldn't q5 and q6 on your board be turned around 180 degrees?
for q6 ebc are fine but the symbol should be turned around 180 deg.
for q5 it should be cbe and the symbol should be turned around.
c's are connected to the signal path and e's the voltage rails
or am i mistaking?
cheers,
c.
or am i mistaking?
cheers,
c.
Re: Re: custom transformer gb?
May I suggest getting a quote for dual primary transformers
(2 x 115 or so)? That way, they can be used outside of
North America as well.
Dennis
Dennis
culture said:Hi cviller,
or am i mistaking?
cheers,
c.
I think he mentioned that he's using a substitute for the ZTX with different pin configuration. I don't see a problem with availability of the ZTX here, but that's the deal.
- Group Buys
- Gb: F5 Pcb
