Gb: F5 Pcb
cviller said:
From left:
Input selection
Two attenuators http://www.diyaudio.com/forums/attachment.php?s=&postid=246385&stamp=1065479349
and two B1 in the end....
It is a single ended control and preamp controlling two poweramps at different level, but same signal - ideal for poweramp ab testing. 😉
That's funny, I thought it was the central office for the telephone company.😀
Anone know how the B1 sounds with the F5?
I thought I read somewhere that it's a little harsh.
Also don't you want to use linear steps since the B1 has no gain
I´don´t believe it sound harsh with b1. B1 sounds almost not at all. Just clear and transparent. But you may be right with too less (no) gain for F5. With some recordings B1 is not even sufficient with Aleph J that has more gain.
Didn´t papa mentioned B1 with gain in future?
stefan
stefan
You don't always need gain. However, I thought a linear taper pot was used in the B1 so it would have it would have a similar increase in volume as an audio taper pot when used with a gain stage. Though, I could be mistaken.
I had read about a possible B1 with gain. That would turn it into a preamp wouldn't it?
I believe the F5 can make some speakers sound very harsh. I have noticed cartridge noise and static mixed in on CD's which I have never experienced before. Sometimes I'm about to chase away the audience when I realize they're on the record... :bawling: HAHA no serious, you can hear all sorts of high frequency content with this amp and that would sound harsh on some speakers or perhaps the material just includes some unpleasant stuff you were not able to hear before. 😉
Or you might look at other components in your chain...
