Gb: F4 pcb
Hi All,
I have been asked quite a few times if I had any F4 boards available or if I would do a GB. So after having enjoyed doing the http://www.diyaudio.com/forums/group-buys/134554-gb-f5-pcb.html, I could just as well make some F4's. 😉
In this thread, I would like to hear if people would be interested in such a GB.
Here is the service manual btw:
http://www.firstwatt.com/downloads/f4_om.pdf
Christian
Hi Christian,
I am curious what PCB CAD program is used to create such realistic looking PCB layouts, it looks really good!
Cheers Michael
I already have the F5 PCB. I tried to get yours, but you were sold out so I went on E-bay. I think I'll get your F4 and a F3, and try them all. I needed to get two mono blocks with four 10" X 6" Heat Sinks. I already have the chassis and transformers. Your PS PCB were for stereo, so I had to get single ones elsewhere. If I can I'll put all three in the cabinets. The boards and components aren't that expensive. The power supply and the rest of it are all the same. I sure want the F4 to work. What do you think?
Ray
Just got a package with a lot of boards today. 😀
Hi All,
Christian
I sure would like to order some F4's. Do you think this project would work:
"I already have the F5 PCB. I tried to get yours, but you were sold out so I went on E-bay. I think I'll get your F4 and a F3, and try them all. I needed to get two mono blocks with four 10" X 6" Heat Sinks. I already have the chassis and transformers. Your PS PCB were for stereo, so I had to get single ones elsewhere. If I can, I'll put all three in the cabinets. The boards and components aren't that expensive. The power supply and the rest of it are all the same. I sure want the F4 to work. What do you think?"
Ray
It sounds like a great plan, but I can't really see the problem. 😉
BTW, you can use one psu board per monoblock - more capacitance is better. 😀
So rotary switches will work for changing the power supply to F3, F4, or F5 with all the outputs mounted on the heat sinks, and then selecting where the
input goes to and output comes from to either F3, F4, or F5.
Ray
Oh I forgot that you wanted everything in one box... it is perfectly doable, but it might not be worth the extra complexity. You need to switch supplies, inputs and outputs. And the F3 psu is not compatible with F4 and F5.
