gaudy and stupid
I wouldn't advise it if you are interested in sound quality.
You see, at the very least you will have added mass, which will change the acceleration of the voice coil. Slow it down enough and the whole thing will just produce mud.
Also, different kinds of paint have different solvents as a base. Even the vapours can produce problems in the adhesives and polymers used in the construction of your drivers.
Finally, if the dust cap is a fabric, some of the paint may make its way into the interior and really screw things up.
🙂ensen.
My opinion is that if you misted a couple of coats onto a paper cap (cloth would be a problem as mentioned) it wouldn't change things very much. Maybe a bit lower end response, maybe a teeeny bit less efficient. I'll bet you don't notice any change at all. Best to have the first coat white so you don't need a lot of layers.
Don't do it unless its a cheap tweeter. The reason why the OW1 and Scanspeak sound so good is because of the coating on the dome. If you change the makeup of that, you change the sound. If its a $20 to $30 tweeter it might be worth a shot for aesthetic reasons.
