nah, this one is weak, cant do solid voltage, shuts off due to undervoltage probably. i've given up for now, probably will revisit it on friday and weekend.
What could i check then?
I guess over the weekend i could check it more, what could i check next? as i no longer have any idea where to look
I do not have it right now, its at a different location. Im there only on week days. On weekends im at home and i only have the arduino
Without having access to the scope, it's going to be more difficult.
I think you need to:
Replace the driver and any blown FETs
disconnect the rectifiers
clamp the PS FETs tightly to the heatsink
insert a 10-15 amp fuse in the B+ line (no current limiting from the power supply)
Power up and check waveforms on the PS FETs if the fuse doesn't blow
I think there is something screwed up with his car, his car has killed 2 more amplifiers 😂
Both of the amps were low power and older.
From what ive been told:
First one blew up randomly while listening to it (2 dead output fets)
Second one blew up after connecting power to it (2 dead output fets)
I removed the dead fets from the second one, but it still worked just fine, so we put it back in the car, listened to it for like 5mins and adjusted the power to a safe level for the amp (estimated like 200w on the output, amp has an RMS of 400w@4ohm).
Later he messages me that he started his car, heard a pop from the back and the amp was on fire, no pics of the amplifiers insides yet, will post when i get the pics.
It's been common for speaker enclosures to grind the speaker wires (feeding the enclosure) into the floorpan of the vehicle to create an intermittent short.
Another problem that was much less common was the speaker having lead-in wires (between terminals and the cone) that were too long and could touch when the speaker was driven hard.
Struggling to understand what you meant in the first sentence. But the speaker wires go directly from the sub coils (after being connected in series to get 4ohm ofc) to the amp, the sub is inverted.
The speaker leads are woven in the spider, so they shouldn't touch
In many of the installations, the speaker wires get under the enclosure and the corner/edge of the enclosure puts enough pressure on the speaker wire to grind it onto the floor of the vehicle. This can either short the two wires together or into the floor of the vehicle (which is ground).
One other thing I've seen (only one time) was the speaker wires shorting where they meet in the parallel pair.
Ahh, in this case that isnt an issue, as the trunk is carpeted and the wires dont go under the enclosure, so if they somehow short to somewhere, it will be to the other speaker cable.
It is very odd that the amps blew up, no idea what could cause them to blow.
No money to get another driver and FETs, but doing some quick checks.
The bank with the healthy FETs gets no voltage from the driver, but the bank with the 1 blown FET gets voltage (3.2v before shutoff) from the driver
Connected to my 12v 5a supply, it draws more than 6a before it shuts off from undervoltage. It would easily blow a 10A fuse.
The frequency on the ps fets probably is too high for my Arduino scope
- General Interest
- Car Audio
- GAS PSP3500.1d going into protect
