G.A.S Goliath
I just answered your AK post. +/- 28VDC. What's wrong with your Thoebe? I can repair it if you need. I'm a GAS/SUMO addict and have almost all of the common units EXCEPT a Thoebe. I rebuilt a Thoebe a few years ago but never got to run a Goliath with it. Can you remove the cover and tell where the wires to the external Goliath connector go. I don't remember if there are some decoupling RC networks between the power supply and the connector, I don't think there is. Both Thaedras have an RC decoupling network between the PS and the head amplifier, that could be why you see +/- 22VDC on the head schematic, instead of +/- 28VDC.
Craig
The top cover, should be some wires, black, gray and white going to the connector on the rear if IIRC. Your Thoebe probably has a bad PS/regulator card. Can you post a picture looking straight down into the unit?
Craig
llwhtt,
Here is a few shots of the inside.
Did you find the wires? Can you post apicture where they connect to the main board? From those pics I would say those are all original capacitors, probably long gone, notice how the heatshrink covering has shrunk down the sides of the capacitors. These preamps, Thaedra and Thoebe, run a tad on the warm side.
Craig
The wires to the power input jack are red and violet brownish. Yes, this was originally bought new so, I guess the heat over time has caused this.
Here is more pictures, I can take more with better lighting if needed.
I found the answer in an email from Mike Bettinger, there's no decoupling circuit, the rear connector is straight off of the regulators. The wires in the one I rebuilt were white and gray, I guess they used whatever color they had at the time. Soooooooooooooo there's your answer +/- 28VDC, don't know what the current is though. I'll figure that out when I get home.
Craig
Since this seems to be a temporary fix, you ARE going to get Thoebe fixed aren't you, I would just get a bench top regulated dual power supply. Probably cheaper than making one. MCM Electronics has #72-8690A for $159 but is backordered at the moment.
Craig
I was studying the Thoebe layout on the Japanese Amp8 site and it looks as tho the headamp is fed from two big resistors so I would shoot for the +/-24VDC. Do your connector wires connect at the end of two diagonally positioned resistors?
Craig
10 Ohms won't drop much voltage at 50 ma. I guess the power supply voltage don't matter all that much. The Head Amp schematic says +/- 22VDC, my Thaedra I, which uses the same PCB has +/- 24VDC and your Thoebe will probably have close to +/- 28VDC. I've never seen a Goliath in person is there any thing in it besides the Head Amp PCB?
Craig
