No clue; what's a 'Water Buffalo'?
Post #34: Miscellaneous designs -Mark Audio, Fostex, TB, Dayton, Seas etc.
jeff
OK, thanks! Did a forum search earlier that only turned up the name in several posts, but no drawing. 🙁
No clue
But if I built one of each of the same tuning, I'd expect to only hear a difference based more on stuffing density than box shape with the 'nod' SQ-wise going to the Metronome.
Thanks GM, I will surf to find some starting points and then play with the simulator. Is this a good starting point for the a11ms I've been suggested to buy? The Metronome
You're welcome!
Your call........ both are suitable for vented specs drivers. I'm a major league MLTL fan going on 57 yrs now for its bang/buck performance, ease of design/build, while a quadratic taper yields a much more interesting/pleasing visuals with a slightly different sonic signature due to how the driver interacts with its shape.
