• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
FS: Various items
Hi all
I did a little research and confirmed the numbers on the driver itself. This is actually a Renaissance Audio modified MW-1075. It measures 4 ohm, not 8.
$75 shipped.
I finally got mine hooked up today in 2 isobaric enclosures, however the 2 front, face mounted ones were noisy. Upon investigation I found that the surround was coming off the frame in a few spots. Turned out that there is hardly any glue on the surround, and gently, using my fingers was able to separate the entire surround, and found almost no glue residue at all.
I will reglue them using a heavy duty rubber cement, and hope the ones that are on the inside, mounted the opposite direction hold.
Anyone who still has some unused, might want to check.
FS: Morel Renaissanse MSW-12.1 Subwoofers, NOS
Hey. Glad they are finally getting some use. I think we had PMd about the glue issue. I discovered that myself on the last few that went out and either told folks or just fixed it myself. It's an easy fix. A result of being in storage for so long.
Thanks!
I have two more of these I want to sell if anyone is interested.
