This passive crossover
CUTOFF frequency depends of parts values and is variable.
Layout of PCB. Dimentions - 170*100mm
May be used with up to 700W speaker system.
PCB has universal to use with different elements sizes. Also is possible to change cutoff freq and attemnuation adding or removing parallel capacitors.
And - final look ^)
For sale:
2pcs - 10$+shipping (about 4,5$)
6pcs - 26$+shipping (about 6$)
PCB only, not assembled!
Exapmle of assembled (with video of testing!) in my blog article (used cheap, not MKP capacitors for demo only).
And - final look ^)
For sale:
Yes, but manufacturing will be expensive (about 70 euro per pair)
Why are you not satisfacted bu these? What kind do you need?
About 1.5kHz... Forgot fine value.Crossover freq?
It is VARIABLE! May be changed in range 800Hz - 3KHz changing by selection of capacitors.
Now - yes. But if You need more - I could order manufacturing of needen number and for one-two weeks send You.You have only 6?
Did you go to blog and watch video with testing? ))
For HT, what about LT?
I did! harasho!
Will send you a PM.
Both 🙂For HT, what about LT?
It depends of capacitors and coils you will solder to the PCB.
Also, If you want, i could assembly crossover for your parameters, but it will be more expensive and take more time 🙂 🙂
😉I did! harasho!
Will send you a PM.
