HPA-nxV101 R2 Signature DIY audio amplifier modules (2pcs.) pair for sale
HPA-nxV101 R2 Signature DIY audio amplifier modules (2pcs.) pair for sale | Audio Tweak
2 pieces (pair) HPA-nxV101 R2 Signature Audio amplifier modules with 6 months warraty. This is DIY highend with high quality components made in Australia by Holton Precison Audio. 200W per channel.
Auction including:
- 2pieces of HPA-nxV101 R2 Signature Audio amplifier module with 6 moths warranty
- Silicon pads, screws and PCB Hex Stand-Offs
- manuals
This modules are great for your DIY project. Modules are in absolutely mint working and optical condition. They have been used for about a week. I can supply them with soldered wires or unsoldered. I’m seeling them, only because I have bought another modules from Holton precision audio for bi-amping. All manuals included. I can give you help and support when you build them. If you need any more info call me on 07500838954
Official webpage of product: HPA-nxV101 R2 Signature Mono Bock Amplifier Module - Amp Module -
The HPA-nxV101 R2 is based on the nxV200 Signature topology, this module is designed to be used in a very compact and powerful Mono Block or two or more channel power amplifier.The nxV101 R2 has a greatly improved onboard low noise power supply, utilising 16 x 1000uf 63 volt audio grade Nichicon filter capacitors which is configured in a RC PI filter arrangement.The use of a large number of small filter caps in each supply rail provides a low ESR, low noise supply that feeds directly intothe power amplifier with the shortest possible connection.
This is actual pictures of modules.
Preliminary Specifications
100 Watts RMS continuous sine wave into 8 Ω Per Channel
170 Watts RMS continuous sine wave into 4 Ω Per Channel
The HPA-nxV101 R2 is 2Ω Stable
Biased into Class A/B
Power Bandwidth 3.5hz to 660khz -3dB
Dampening Factor At 100hz 8Ω = 800
Dampening Factor At 1khz 8Ω = 650
Dampening Factor At 10khz 8Ω = 250
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
Signal to Noise Ratio -110dB
Recommended Linear Voltage Supply +-50 volts DC
Operational Supply Voltage Range +-10v DC to +-60 volts DC
PSU Power Transformer secondary windings 0-35vac + 0-35vac (500VA to 625VA)
Printed Circuit Board Dimensions 265mm x 47mmx 25mm
Recommended Minimum Conrad Heat Sink MF35-50 to MF35-100
Ready for immediate dispatch by Courier or collection from Folkestone, Kent. I accept Pay Pal, bank transfer or cash upon collection. Shipping worlwide. I can help you with shipping declaration
Grab yourserlf a bargain!
Original price £380 now £149
Auction including:
- manuals
Hi Teti,
would you accept £150.00 for the modules to include post and packaging to the Isle of Man?
(I can make payment as soon as I am back from work this evening)
Best regards
Best regards
jerryo said:I am very interested in these amps, so please consider them as sold as long as we can agree on the price.
I saw them on eBay and thought they might appear on the DIY Audio Forum.
I have two toroidal transformers waiting just for amps like these.
625va with 2 x 35v secondaries!
Cheers
Hi there, I can send you a PayPal invoice, so you will have protection by PayPal, or you can buy it on eBay (which using same buyers protection) HPA-nxV101 R2 Signature DIY audio amplifier modules (2pcs.) pair | eBay
ebay auction: 281103333960 (if a link ain't working)
Price is £150 + Postage - sorry I can't go any lower. They are well wort their price.
Comparing to £4000 McIntosh MC275, source £5500 MSB platinum DACIII didn't end up that bad. Lacking and sweetness of mcintosh, but with superior bass and some of us thought more realistic vocals.
Martin
Shipping world wide £15.50
Germany and France, Belgium, Channel Islands: £12
UK, including the Highlands and Islands, Scilly Isles, and the Isle of Man: 1st class signed £5, 2nd class signed £4, next day special delivery £8.50.
