Frugel-Horn Mk3 Builds & Build Questions
I have just finished 1 of my two MK3 with Merrill DCA4 drivers. I am new to full range speakers and unsure of the obtainable bass levels. At the moment they sound clear and sharp on vocals and give a strong punch at highs.
I am happy with the result so far, my first speaker build so it is nice to hear the results.
kec said:
This past weekend, I swapped the CHR's for the Tang Band W4-930SF.
Interesting... Whenever I get around to making headway on my dual EL70 "Castle" microtowers, I may order a second set of 930SFs and try them as well, just for shirts and giggles. I have a pair of the 930SFs in Minimus 7 cabinets and like them VERY much. But as for 3 vs 12 Ohm speakers...
I only have stuffing behind the internal baffle pretty much as the damping plan looks. I have none in front on the internal baffle. could you explain more on what should i expect from changing the stuffing around. (more, less, none, in front of baffle, behind.)??
Thanks!!!
Maybe he's referring to these...
If I'm not talking out of place, Scott would likely be awaiting opportunity to see field test data the new WK series before modeling any new enclosures, but even then it (revised Fostex designs) wouldn't be a top priority.
If you already have the FE167E on hand, there are already some well proven enclosure designs from the drawing boards of Scott, Dave and Bob Brines. Of those, I've only heard one design.
