Front Panel Express Files
I just did a few layouts of pcb boards in Front Panel Designer and I though I should share:
Twisted Pear Audio Buffalo II
https://docs.google.com/open?id=0Bw7Hr91Jz0_aXzRsLVdVR2hjYkk
Twisted Pear Buffalo III
https://docs.google.com/open?id=0Bw7Hr91Jz0_aUkxLRkt4SWNWSEU
Twisted Pear Audio IVY III
https://docs.google.com/open?id=0Bw7Hr91Jz0_aRnplUmJITHpDZkk
Twisted Pear Audio Placid HD Bipolar
https://docs.google.com/open?id=0Bw7Hr91Jz0_aYnAzMW4tdDJHcnc
https://docs.google.com/open?id=0Bw7Hr91Jz0_aUnZ6SE4wQkRWblU
Cavalli Kan-Kumisa III
https://docs.google.com/open?id=0Bw7Hr91Jz0_adjdoZjFLTlQ2a0k
AMB B22
https://docs.google.com/open?id=0Bw7Hr91Jz0_aTWpGaVY4QzhnTFE
AMB S22
https://docs.google.com/open?id=0Bw7Hr91Jz0_aUFZQYVlwSW9WOG8
These are useful to when doing layouts of builds and also when ordering drilled panels. You can easily make macros of them as well. I took the measurements from Twisted Pears and AMBs websites.
New Additions:
Hifi 2000 chassis panels:
Galaxy GX14X front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aTmEwdVcxRmNCd3M
Galaxy GX14X back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aZi1ucHJuSWVPNzQ
Galaxy GX24X front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aOTRxa1p0Y0VvMDA
Galaxy GX24X back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aeDNNNm13VWdlTmM
Galaxy GX34X front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aSzBHbkJ6YkI5dFU
Galaxy GX34X back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aeWdLNlJzbVZ1SUk
Galaxy Maggiorato GX18X front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aejRIN1hvSENtSHc
Galaxy Maggiorato GX18X back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aT1h6Q3BqT2RCWXc
Galaxy Maggiorato GX28X front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aN2lydk5ybWNJcUU
Galaxy Maggiorato GX28X back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_abV9iZXJuT01hbXc
Galaxy Maggiorato GX38X front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_abW8teFJYdU0teGc
Galaxy Maggiorato G38X back
https://docs.google.com/open?id=0Bw7Hr91Jz0_aZm00bUU0YXhzWms
Slimline 1U front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aTVBIR0xmZ0ljeUE
Slimline 1U back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_ac0VGb0s1QVNycVk
Slimline 2U front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aNGNaeGRBWTNMb2c
Slimline 2U back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aVThMYkJxMkFvbG8
New additions 2012-05-09:
Pesante Dissipante 4U front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aZFA3cDhDQXZEUXc
Pesante Dissipante 4U back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aMmJHZWQ3QWl5RzQ
Pesante Dissipante 5U front:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aamtkMnVheURvVHM
Pesante Dissipante 5U back:
https://docs.google.com/open?id=0Bw7Hr91Jz0_aX0R0X3NqYnNNdjA
Keep in mind that I've never seen a Pesante Dissipante case so I just had the files from Hifi2000 to go on.
if you want it moved dont wait for them to stumble upon your post, use the report this post button in the bottom left with the exclamation mark and tell them you would like it moved. handy documents mate!
MrMajestic:
This is quite helpful, and I would encourage you to add other HiFi2000 front and rear panels. Given that the moderators of this fine site are poised to start selling Pesante Dissipante 4U and 5U enclosures, the addition of the front and rear panels for those enclosures would be especially nice.
Scott
MrMajestic:
Scott
I uploaded files for the 4U and 5U. Please bear in mind I've never bought an actual case they are just made from the files I found on Hifi2000.
Front Panel Express
Hello MrMajestic, Thanks for all of these. I must be doing something wrong, I've d/l the front panel express designer tool, but when I open these .fpd files I just see a panel with 4 holes in the corners (in the example of the Buffalo III fpd for example). I can't figure out what other 'view' or other option might be possibly wrong, so that I can view everything in your designs... any clues for a newbie to FPE?? TIA, /Mike
You are not doing anything wrong. The Buffalo III file is just an outline of the Buffalo III PCB so you can do a case layout. The Hifi2000 files are empty panels with only the mounting holes.
