Hi!
Been reading this forum for quite a while, gathering info, experiance etc. Now I'm ready to build my first DIY projector. I have two very good lenses (each with 6 lenses ) with 220 mm FL. Preliminary tests show great focus abilities along whole LCD. I guess an 220mm Fresnel will match this lens perfectly.
-But, if my 220mm Fresnel is an inch or two in front of LCD (for Fresnel tilting), I will have a missmatched setup - focus points of triplet and fresnel will not mach. What is your advice ???
-Which Fresnel is better to use on the oposit side of LCD (between light source & LCD), 330mm or 220mm ?
-One more thing: I know that it's best that the field Fresnel and the triplet match up in regard to focal length right? But can you go with a mismatched set; which is it? A longer focus Fresnel or a longer focus triplet? What are the disadvantages of that setup ?
Every advice is welcome.
Thanks !
Thanks !
Not to be a pain but, please search before you ask your questions. This has been covered many times and recently too (last week).
http://www.diyaudio.com/forums/showthread.php?threadid=65009
This discussion is exactly what you are asking.
