This type of remote makes only sense when using transformers. If you want to use resistors and have the convenience of remote control, Apox system is probably a better choice and comes in about the same price as the remote only.
Joined 2003
24 Stepped switch
<IMG SRC="http://tw.image.bid.yahoo.com/users/0/6/6/8/kyc_111-img600x350-1068937145dsc00004-2.jpg"><br>
<IMG SRC="http://tw.image.bid.yahoo.com/users/0/6/6/8/kyc_111-img464x525-1068937182dsc00006-2.jpg"><br>
<IMG SRC="http://tw.image.bid.yahoo.com/users/0/6/6/8/kyc_111-img600x464-1068937227dsc00008-2.jpg"><br>
Joined 2003
Hello Raka,
Your e-mail option is disabled, so please contact me at: safeway-at-xs4all.nl.
I have some info for you.
Thanks,
Franklin
Thanks,
Franklin
Hard stop or continuous revolution?
I saw something in the construction manual about using only 23 of the 24 positions so it won't have a 'full-revolution' design. Does anyone know if there is a hard stop at minimum volume to keep you from going past minimum to the maximum position (going directly from position 1 to position 24/23)?
-Greg
-Greg
"Does anyone know if there is a hard stop at minimum volume to keep you from going past minimum to the maximum position (going directly from position 1 to position 24/23)?"
Personally I would not mind, I could probably make a mechanical stop however I think these are full rotary selectors without any dead stop...
I hope I am wrong but some year ago I saw similar rotary switches that were actually made for pc use being sold as readdy to assemble attenuators with the resistors in HK (very very cheap in store)
J-P
J-P
For info, I bought one of the EBay ones and received it in just over a week from Tawain. The build is excellent - it is certainly as good if not better than the picture. I know that given enough time and patience, I could solder one up reasonably well but I do not think I could come close to the quality of this work - it looks like it was done on a jig. I haven't tested it yet but if it sounds as good as it looks, I will be ordering more.
(No, I do not know the seller nor have I even communicated with him).
Joined 2003
The rotary switches used to build those attenuators are nominally 24 make before break pos. switches.
You give up position #24 by putting a mechanical stop there, often just a small blocking screw.
I don't think there's a way to have all 24 pos. and have a stop at the same time...
Not having a stop there would be risky as you could go from dead quiet to full blast by just one click.😀
Cheers, 😉
Cheers, 😉
i was thinking
of a mechanical soultion something that prevents the KNOB from turning, so a deadstop, a small pin or so, attache to the bottom of the knob not visible from the front...
J-P
gezondheid, das iets wat hier maar triestig opgevolgt wordt!
J-P
I would just sacrify one of the lowest volume position, for the stop. I'd rather have full gain (if needed) and don't have for instance -60dB position (as I never use it anyway). But stop is definitely required.
RE: I WAS THINKING.
Sure, that's what that little screw does.
The problem is that you don't have enough space to put anything on these ELMA switches.
Cheers,😉
Cheers,😉
Ah,ah...I see what you mean now: on the dial side, right?
That's a possibility but for all practical purposes I find 23 pos. more than I ever need.
At home I have attenuator usually set between ps. 9 and 11.
If you use a switch to mute the preamp then you could consider that infinite att. and pos. -24 if you like.
Cheers,😉
Cheers,😉
Joined 2003
Re: Stepped switches
What is the price?
Do we get a volume discount, if we buy many of them?
Do you off them as kits, and fully assembled?
Randy
kyc said:hello
I'd love to provide the Stepped switches.However,I hope that there is someone who can collect payments and items for me.By the way,I'm not good at English.
What is the price?
Randy
- Design & Build
- Parts
- Found: source for cheap ladder attenuators
