Fostex P1000E Speaker Kit?
Just got the speaker kit today and have been playing them for quite a few hours. I have to say I'm quite impressed. I'm using the cabinets that came in the kit for a few weeks until my custom cabs arrive but the mids and highs are stunning and when combined with a proper subwoofer, it is quite magical. This was well worth the asking price in my opinion.
And here they are at work. Sounding fanatic with a small subwoofer crossed over at 100hz to pick up where the FE103-SOL's leave off.
Hi audiophile03,
Post #10: "...wanting to eventually learn how to make speaker enclosures..."
xrk971 has started somewhat of a craze, but it's all good :):
http://www.diyaudio.com/forums/full-range/223313-foam-core-board-speaker-enclosures.html
http://www.diyaudio.com/forums/full-range/239338-mini-karlsonator-0-53x-dual-tc9fds.html
http://www.diyaudio.com/forums/full-range/247598-nautaloss-ref-monitor.html
http://www.diyaudio.com/forums/full...k-building-cornu-spiral-horn-now-you-can.html
, and there are more. Xrk971 likes the Vifa TC9FD's not just because of the cost:
Vifa TC9FD-18-08 3-1/2" Full Range Paper Cone Woofer
As to the Fostex drivers, I lean towards the 103, but I never had both of them side by side to listen to.
Regards,
Thanks for the links! Those are some very interesting enclosure designs! I do plan on buying the tools to start making enclosures next year, not to mention, my new house I am moving into has a third separate garage I can build into a wood shop. This forum has inspired many different ideas to try.
Nice :)
A couple comments/queries:
1/ Is the vent length adjusted to deal with the flare?
2/ With solid wood baffle you could have a sonically better big round over on the edges
3/ thick hook up wire.Solid or stranded?
dave
Yes, he plugged the speaker dims/specs into his drafting program and designed the cabinet and port length to give it the best response/range. Not sure on the cable, but I think he may be using silver stranded stuff. I'll soldier it to the terminals when I get it. I'm thinking of finding some bronze screws to match the speaker frame.
