Do any oif you have any information about this amp???
I just got one and need some information about it. Any source of tech specs??
Eduardo
Eduardo
I asked this same question a while back regarding the Lab 600 and never got any replies. I guess these weren't all that common. I have since managed to source the service manual from our local Fostex agent and it covers the 300 as well. Try you local agent if there is one and if you don't have any success let me know and i can get you a copy.
John
John
I tried the spanish fostex already
Thank you for your offer, it is just what I needed. I contacted the spansih fostex imported BEFORE even getting the 300 amp and they knew nothing about it.
They are only involved into digital recording and know nothing and have never imported any power amps.
Are you happy with your amp?
Can you send me a copy of the manual?
if you have any cost tell me and I will send it to you
THANK YOU VERY MUCH
Eduardo
THANK YOU VERY MUCH
Eduardo
Eduardo,
I've sent you an email...
I like this amp a lot. Haven't had it for long - I need to do some repairs to it before any critical listening - someone has replaced some components in one channel so they are not identical.
At first listen it sounds very detailed, quite bright. Serious control of the bottom end. It's really well built, 1.3KVA mains transformer!!!
Some of the transistors are obsolete but a company in USA called consolidated electronics has all of them.
It has a low level hiss which I need to cure which is audible on my 15" Tannoy's but not on less sensitive speakers.
I reckon it's worth spending some time and effort doing some minor improvements.
John
John
Hi John,
It must be an obscure amp for noone to reply to your posts 🙁
Could you send me the manual too?
My address is craigfini@hotmail.co.uk
Cheers
Craig
Cheers
Craig
I always end up unintentionaly finding (and liking) the obscure stuff! They say you can find info on anything on the net... try googling these amps! 🙂 There seem to be a few arround these parts - mostly out of theatres and cinemas. I was mighty suprised when the local agents said "sure we've got the manual, we'll make you a copy" Craig, I'll drop you a mail shortly. Have you got the 300 or 600?
TheJohn,
The amplfiier i have is the 600 like yours, just got it off Ebay today at a pretty good price.
Yes the internet has absolutley no information on these amplifiers, its quite suprising.
Speaking as someone who has listened to the 600 how does it sound compared to other hifi amps?
Craig
Craig
It's really hard to say definitively as I haven't done much side by side comparison. Until recently was running Genelec 1031's which are active. Just finished building boxes for my 15" Tannoy 3836's and suddenly I needed an amp! Used my old Lexicon (made by bryston) for a bit, then was offered a good price and sold it - borrowed my neighbour's old nad 3020i and just used the power amp section. Figured I didn't need much power as the speakers are very efficient. Was amazed at how good the nad sounded!
Got the Fostex - as I mentioned above, it's had some dodgy work done to it so I doubt it's performing optimally - but it's a different amp to the nad. More detail, cleaner tops, huge bottom end control - haven't switched the subs on for a couple of weeks now!
It's my type of amp - clean, clear, uncoloured, some might say clinical, super-detailed. I prefer this to the warm, fuzzy, feel-good amps some people claim is hi-fi. I want every component to be as revealing as posible to defects in the rest of the chain. I'm still going to do some work on the amp and clean up some of the shoddy work, clean up some of the wiring, try and quieten it down a little - joys of sensitive speakers, you can hear any little hum / hiss!
I would like to hear your thoughts once you've had a chance to listen to it... If you don't like it you can always send it to me! 😀 I'm building a matching 15" centre chanel and will need another amp!
Im glad to hear you consider the amplifier to have a nice sound.
I really wanted an amplifier with good bass control as my speakers only have 2x8 inch bass drivers each, hopefully better curent delivery will help with their bad bass performance.
I am hoping the amplifier i purchased will be in full working order and have unaltered internals so if you need and info on its guts for your reconditioning i can provide you with it.
The amp was sold to me as untested, i am just hoping if there is a problem it hasnt blown the output transistors, theres a lot to replace!
Sure ill let you know what i think about it's sound, although im sure it will beat the cheap Hitachi HA-3 amp i was using until recently.
Craig
Craig
HI,
Ok i received my amp yesterday and have been slowly testing it since.
I have begun to bias it, although i dont trust my multimeter to be calibrated correctly ( i have 3 and they all say different things) 🙁.
Approximatly what position do your output bias pots sit in for
5-10mA idle current? i think mine is very much underbiased as it came with pots set to max resistance (twisted all the way to the left) and since i dont trust my multimeter im concerned about increasing it.
Just wondered if the smaller transistors ( the ones with the clip on heatsinks) on your lab 600 get quite hot to the touch after a few minutes of idleness? im trying to be very careful with this amplifier theyres too many output transistors for a cheap replacement!
Other than the bias and heat niggles it all looks good.
Craig
Craig
I now have a multimeter that i can trust.
Just noticed the bias seems to creep up from less than one millivolt up to around 8mV then i turned it off, is this normal behaviour for this amp? it suggests to me that the transistors in the bias network are getting warm fast and that this may cause thermal runaway.
Open to suggestions from everyone regarding this.
Heres a link to the schematic in another thread:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=79232&highlight=fostex+600
Craig
Craig
Hi John,
That would be great, like i have said my main concerns are the bias drifting (it does stabilise after about 15 minutes) and the transistors with the small clip on heatsinks heating up. If you could check your amp for the same things it would be very interesting.
Also what volatge are you running it off?
with 220v i get +/-75vDC rails as per the schematic but with my pure mains voltage ( not through a variac 240V) the rails are 85v dc which is quite a lot and is a danger to the transistors used in the circuit.
Check out the other thread i started :
http://www.diyaudio.com/forums/showthread.php?s=&threadid=81986&perpage=10&pagenumber=1
Craig
Craig
Hi I am glad to have found this post on this forum.
Found the 300 at a second hand shop for about the equvalent of $60. My eye catched on the name Fostex and I was so exited that I didnt even asked the busy shopkeeper to test the unit.
Now for a good cleaning and sound test. Thanks for posting the spec sheet.
Jan
Jan
John, you have turned the Fostex amp collection world on its head 🙂.
Quite and impressive collection you have there. What was their main application in the 80's? movie cinemas? Is it class AB? Do the 600 run hot?
What speakers do you drive with the 300 and do you recommend any modifications, upgrades to old and weary parts?
Sorry a mouthful of questions 😀. and the discussion is open to anyone interested in this solid Japanese amp.
I like the heatsink structure.
At the moment Im testing the 300 on a ancient pair of TEAC sx-500 speakers. Straight from the cd player to amp. Find the sound to be impressive.. fast and clear.
I too have a large collection of these wonderful amplifiers plus about 37 years of experience with them being the person who introduced these products in about 1978.Quite and impressive collection you have there.
I don't know the South African market but, in North America these amplifiers were and continue to be used almost exclusively in recording studios and broadcasting.What was their main application in the 80's? movie cinemas?
These are the recommended amplifiers for use with the RWO/Fostex Laboratory Series Studio Monitors.
The amplifier is Class AB and runs very cool.Is it class AB? Do the 600 run hot?
The phone plugs can become intermittent. The level controls and switches should be cleaned. Beyond that, there are no recommended mods.do you recommend any modifications, upgrades to old and weary parts?
- FOSTEX 300 laboratory power amp
