Have you checked all of the driver transistors and djodes in the output drive circuit?
I wouldn't power it up without the resistors. You could use 2 of the 8 ohm 25w in parallel. You can get those from radio shack.
You could try fuses (3A?) but I don't know what value would best protect the outputs.
Monitor the temperature of the resistors so that they don't get too hot. Use a tie-wrap to hold them together. If the tie-wrap begins to melt, you know there's a problem. Also, this is only to be used until you determine if the output section is working properly (producing clean audio, not drawing excess current...). You won't be able to drive a speaker load with these in the circuit.
sorry it took so long. when i got home from radio shack last week i saw one package of resistors was missing out of my bag. now i got them. the 4-ohm 40 watt resistors are not even getting warm. here is a pic of the out put (60hz wave). notice how it is a little shakey on one side. is that okay? i have not put a load on the amp yet.
Without a load, it's difficult to say if it's normal. Sometimes the output filter can cause distortion like this when it's not loaded. Try it with a light load (4 or 8 ohms) and drive it to a point where it starts to make the resistors heat up. If it's clean, remove the resistors and try it direct.
When you remove power, remember that the caps will remain charged. Discharge them before touching the red and blue wires.
- General Interest
- Car Audio
- fosgate t40001bd bad p/s
