Fosgate T2500-1bdCP
Working on the power supply of a T2500-1bdCP. Would anyone know why Fosgate would use 47 ohm gate resistors on three of the mosfets and 60 ohm on the other nine? I think it's original. Don't think it's been worked on before.
Rebuilt the power supply driver board and replaced SMD drivers on the main board. Drive signals are good and equal to all power supply mosfet gates. Gate resistors are all good. Loaded each transformer with two mosfets. One power supply mosfets run cool at idle. The other runs hot. No outputs or rectifiers in the amp. Draws 3.6 amps at idle. Is there another reason, other than the transformer, that the mosfets would run hot with no load on the secondary?
This set of pics is the bank not getting hot. Signal is the same on both banks of this transformer. I only took pics of one mosfet.
Here's pics of the bank getting hot. Both banks of the transformer are the same. I only took pics of one mosfet.
