I have a Rockford punch 250
there is a mosfet blown but I cant find any info at all, strange
its a 5nq5hd, I looked on mouser and TI but don't see this unit
what am I doing wrong
Look here
Semiconductor and Integrated Circuit Devices
for
mtp75n05hd
The mtp version seems to be obsolete.
But the mtb75n05hd should be still available.
for
mtp75n05hd
here is a photo of another Rockford I have had for 15 years,
I ordered the caps for this last week, first ones came back half the size I needed but they had the same spec's 333 25v had to reorder some 25mm tall guess you can tell im very green even at 50 years old, I picked up my first breadboard and a very nice
Tektronix 2245A 100Mhz 4 channel Oscilliscope
just need to learn how to use it
I hope these are not counterfeit, picked up off ebayLook here
for
mtp75n05hd
MTP75N05HD Manu:MOTOROLA Encapsulation:TO-220,POWER MOSFET 75 AMPS, 50 VOLTS
Hi Tekko,
I always thought the role of the angry old man is mine!
Today I found my master.
Anyway, true. Ebay is a high risk source for semiconductors.
Still, I bought a bunch of LM4562 on ebay and measured step response (config for step response: non inverting gain = 4) and noise (gain=1000) and offset (gain = 1000) in direct comparison vs my samples which I directly ordered from TI.
==> Identical noise and step response. Slightly worse offset with the ebay types, but easily in spec. Seems like this ebay purchase was not counterfeit.
@Ken
Wishing you good luck.
You will need it with the MosFets and also regarding the likelihood that not only the MosFets might be blown, but also other components.
Hi Tekko,
@Ken
@Ken
yes I was just looking at that 680 resister, I have a hot air soldering iron but dont think I have surface mount resistors
I guess for the low price I can use these for breadboard project, from the photo they dont look like the cheap counterfeit, but lets see what shows up. the seller has some questionable feedback but none for these components. don't know if I can tell the difference even when I get them.🙄About 80-90% chance of those beeing counterfeit. Never ever buy power mosfets off of ebay!!!
- Class D
- Fosgate MOSFET cant find any info?
