Yep, it was due to the images pointing to where they shouldn't have 🙂 Thanks for reporting the problem.
bin the "phone" and buy a "phone" that operates as a real mobile phone and not as 72 gadgets doing each badly.
Double clicking on a sub-forum's bulletin board icon, no longer marks the sub-forum as read.
I'll look into this. The multi-quote button has stopped working as well.
The updating of recently viewed threads has stopped updating.
First thing this morning I clicked back to Search results and thet last thread I had read was greyed out.
When I clicked back a second time after reading the second thread that second thread remained bold.
I have come back in after a couple of hours and the update is still inactive.
Icons above the Quick Reply box no longer work. This seems to coincide with a minor change in behaviour: posting a Quick Reply no longer just puts you straight back to the thread with your reply added, but now goes via an extra screen which used to only appear when the thread was extended to an extra page.
I suspect Jason is working on the site, attachments are no longer working either. I've posted a note backstage, so please bear with us.
spacing in between sentences is not working properly.jerhttp://www.diyaudio.com/forums/planars-exotics/181041-my-2-nd-esl-attempt-3.html#post2542380
Menu bar across the top is not working properly either (drop down is not available only the headline links) tried in both firefox and ie. Tony.
Menu bar not working, can't click on smilies, cant get to wiki etc, can't use any text formatting, or anything that wraps tags around things. I guess this will all be fixed in time 🙂
There is some back room maintenance happening today. You will likely see odd things until it's sorted.
Thank's does that mean the smileys and edit function will work again? RegardsM, Gregg
quite unusable except for basic text communication ... smiles - attach and everything else in the reply toolbar is non-functional.OS
- Site
- Forum Problems & Feedback
- Forum not displaying properly today...
