• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
FOR SALE
FOR SALE 800 WATT SPEAKERS:
TWO 800 WATT 8 OHM NWX-18100 BY MADISON AMPS, RAW SPEAKER - PRO AND PROTECTION GRILL.
SPEAKERS ARE NEW IN ORIGINAL BOX , EXCELLENT CONDITION. 4 KAPTON 100 OZ MAGNET IMPEDENCE 8 OHMS FREQUENCY 25 -3000HZ SENSITIVITY 95DB, RMS POWER 500WATTS, MAX POWER 1000 WATTS ITEM READY FOR IMMEDIATE SHIPPING.
Key Features
100 oz. magnet
4" copper clad aluminum voice coil
cast aluminum basket
gold binding posts
vented pole piece.
ribbed (non-treated) paper cone
double rolled cloth (treated) surround
slightly larger basket than normal, requires 16.875" mounting diameter hole cutout.
Retails for $209 each
NWX-18100
Size
Magnet
Voice Coil
Frame
RMS power
Peak power
Freq. Res.
Ohms
Effeciency
Fs
Qts
Qes
Qms
Vas
Re
Rm
Le
BL
Cm
Mm
Rm mech.
18
100oz.
4"
Cast
500
1000
25-3000hz
8
95
41.03
1.23
1.34
14.82
12.82
6.69
80.52
2.43
14.56
91.14
165.10
2.87​
All woofers are rated at minimum power and efficiency. They test at much higher power and play at higher db. In most cases the efficiency is greater by 4db per woofer listed. Tested at sea level; vas, efficiency and other major parameters will change
