FOR SALE 800 WATT SPEAKERS:
TWO 800 WATT 8 OHM NWX-18100 BY MADISON AMPS, RAW SPEAKER - PRO AND PROTECTION GRILL.
100 oz. magnet
4" copper clad aluminum voice coil
cast aluminum basket
gold binding posts
vented pole piece.
ribbed (non-treated) paper cone
double rolled cloth (treated) surround
slightly larger basket than normal, requires 16.875" mounting diameter hole cutout.
Retails for $209 each
SPEAKERS ARE NEW IN ORIGINAL BOX , EXCELLENT CONDITION. 4 KAPTON 100 OZ MAGNET IMPEDENCE 8 OHMS FREQUENCY 25 -3000HZ SENSITIVITY 95DB, RMS POWER 500WATTS, MAX POWER 1000 WATTS ITEM READY FOR IMMEDIATE SHIPPING.
Key Features100 oz. magnet
gold binding posts
vented pole piece.
NWX-18100
All woofers are rated at minimum power and efficiency. They test at much higher power and play at higher db. In most cases the efficiency is greater by 4db per woofer listed. Tested at sea level; vas, efficiency and other major parameters will changeSize Magnet Voice Coil Frame RMS power Peak power Freq. Res. Ohms Effeciency Fs Qts Qes Qms Vas Re Rm Le BL Cm Mm Rm mech. | 18 100oz. 4" Cast 500 1000 25-3000hz 8 95 41.03 1.23 1.34 14.82 12.82 6.69 80.52 2.43 14.56 91.14 165.10 2.87 |
