Door skins huh?
I'm not sure the extra stiffness is necessary when you look at the walls. Except for where the horn exits, is there any difference in SPL on either side of any channel? Why does it need to do any more than it is?
Not necessary IMHO. The outside facer limits expansion and the inside of the scored piece is of higher compression. The glue is only for your mental well being and possible smoothing the curve which, less face it, is low on the totem pole when doing this.If you seal the scored skin with white glue after it is bent in place it will be even stronger.
Initial impressions tell me that chamber and horn stuffing will look after many concerns of driver matching.WIthout modeling but scaling throat to match Sd seems to work well. I think this horn is so efficient it is forgiving to strict driver matching.
I asked Daniel that years ago and the largest I see to date is either a 6.5" or 8"Is there any reason why the spiral pattern can't be taken larger?
I will be buying a bunch of foam core monday, and proceeding with this fantastic project. SHMBO actually likes the idea!
What about different lengths of bifurcation?
You guys deal with bifornication things, I will use simple thoughts at this point if that's ok. 😉
A scalable trace of the spiral
I found going to the repro guys was a real time saver. Full size made it easier. They had it ready in 15 minutes and charged me $6.05 for 2 copies. I didn't ask for change from my 10. 😉
Is it possible to use the Visaton B200 for this project?
BBIIIIGGGG!!
dave
Visaton B200?
Wow, they would be beeeeggggg! Simple math/scaling says that the original design is for a 4 inch driver, the Visaton B200 being 8 inch, everything doubles. So the dimensions of the box are 150 cm square and about 10 in thick. You would need a double sided Cornu for 8 horns per driver. The sound with 96 dB of sensitivity would just be mind boggling if you think how big the mouth area is. The effective piston area of this driver is 214 cm square cm, the expansion ratio is about 24x this means the total mouth area is about 800 square inches! Oh, and I forgot to mention that bass freq would reach sub-audible to about 18 Hz. This would be something to see and feel.😱
BBIIIIGGGG!!
dave
Yes.
Not the foam core I have. It is XPS so the density doesn't change. At that thickness it is extremely flexible but as you pointed out, you have to score the inside of the facer. The outside will expand a very little, but the facer on the inside won't compress, it just buckles, so what you are doing by scoring it, is to relieve that buckling as you bend it. The outside facer helps to control the compression of the inside so you end up with a nice dense material at the curves even though you have scored it. Nice trick BTW, xrk. 🙂
Ya, no sheep dip. 😀
I meant that the Cornu assembly as a whole resembles honeycomb in that it has faces and perpendicular core that is strong in compression which is bonded to faces to make very light stiff structure. Yes, I really like how the scoring and bending the foam core worked out. So much so it has really opened my imagination to future projects with more curves. Not afraid of no stinking curves no more! This really opens up front facing horns for the mid/highs from the driver using multiple meridians of curved foam core for the ultimate horn.
Ive just drawn up a new tapped horn to build for the other 70mm drivers i have. i started with a throat of 90mm x 16mm to roughly equal sd. With a mouth of 90mm x 80mm and a horn path of just over 1m . so i plan to buy some more foamcore and some dressmakers pins and get to more cutting on friday. Ill try get some more pics up tomorrow of my folding method and somehow try to hornresp it.
Cool! Looking forward to seeing it. You are not the least interested in the Cornu?
Most certainly am interested. My focus at the monent is good quality portable sound. So cornu wont fit in pairs under my laptop. Lol.
Nah i have a nice pair of two way four inch car speakers id like to try. Theyre Alpine TypeE car speakers. Not sure where id use em tho....
I agree that internal walls shall remain foam core as it is stiff enough and may even provide some acoustic damping of higher frequencies, but major selling point is that it makes the build of the curved spirals pretty easy - pretty much the crux of the problem why more folks haven't tried the Cornu spiral before. I was just thinking of the door skins for nice looking facing kind of like veneer to apply to the foam core covers. I am still sticking with foam core for the major structure to the extent possible as I don't have a workshop or power tools other than drill and jigsaw.
For portable stereo sound, try the simple one fold wall hanging transmission line mentioned earlier in this thread but scale it down. It sounds very good with super bass extension and a nice even round feeling that everything is all there. To make more compact, maybe fold it three times but keep it fairly flat circa 2.5 to 3 inches. Check out Cal's sig line in his projects he has several portable speaker systems. My fav is the Pentagon tower with 5 sides each with what looks like 3 in drivers and a tweeter with the amp inside the tower. Not sure how he manages stereo with 5 sides???
I am starting on the Son of Cornu (14 in square desktop horn for 2 in pc speakers). I just laid out design on foam core. I am making all walls curved to extract as much sound from these tiny drivers. The channel depth will be 2.0 inches.
You are owed them and even even more. You helped me scratch a long standing itch.
To possibly include a silkscreen cover over the drivers.
WHAT? I CAN'T HEAR YOU, I HAVE TO GO TURN THE BASS DOWN.
There, does that simplify it?
Cal,
You are welcome - It does look like you have had a thing for these spirals for some time now and am glad you were finally able to scratch that itch. You have even spoken to Daniel, the original designer/builder? It was worth the wait but I'll bet you are wishing you did this earlier as it sounds so good.
I am interested in more of your observations/critique of the sound once you get to mount it in a better location and have more time to listen. I don't think it is ever a problem to have too much bass with a horn as this allows easy fix with stuffing and one can adjust it down to suit and skip the whole BSC network. It's nice to have direct connection from amp to driver with nothing to add funny business along the way.
Do you have any recommendations for a good 2 inch full range driver? I am trying this next to make the desktop Son of Cornu. It's really an experiment to see what the limits of the size/scaling is. I am not expecting it to work well but I may be pleasantly surprised. The earlier poster may go the other way and make the 8 inch monster Mother of Cornu with the Visaton B200.
regards,
Xrk971
Visaton 2231 FRS5 2" full-range from Parts Express🙂
This looks just like the speaker I pulled from the Logitech S 120's. It just has one less small hole on the mounting tab but otherwise looks the same with paper cone and foam surround. A bonus is it is 4 ohms, the back is labeled just 5 Watts, 4 Ohms. The cost of a pair of S 120's is lest than one of these drivers from PE. Plus you get a 3 Watt amp with 3.5 mm jack and PS.
I was thinking of a fancier Tang Band or something like that with a lower Fs. Any recommendations there?
If I were to try one it would be the Tang Band W2-803SM🙂
Argh! Could be a problem to "hide" the monsters in the living room. I don't mean to bug you guys with noob questions. Can you point me to a simulator or formulas that would help me test ideas? For instance, given that I wouldn't care for such low(18Hz) bass, what if I use the B200 with smaller/shorter spirals?
BTW, found an easy way to draw perfect spirals of any size.
To calculate the lowest fundamental 1/4 wave freq, divide speed of sound (about 342 m/s) by 4 x the path length of the longest channel in meters. For example, for a 1.5 m path, 342/6=57Hz. Use current design but modify by putting bigger central box for speaker chamber, this will only add 4 in to your overall dimensions, but the depth still has to be like 9 or 10 inches to let the driver have enough room to breathe.
- Full Range
- Foam Core Board Speaker Enclosures?
