flush mounted in wall studio monitor, any advantages???
I am thinking about building a false wall, or perhaps more accurately a gigantic speaker cabinet that blends into the walls of a media room (about 15 x 17 in size) to allow for large sealed woofer volume and also flush mount drivers on a continuous baffle to minimize difraction effects. Not sure if this makes sense or not but I remember seeing a really cool posting on a audio forum where an engineer had done this with some modest vifa drivers and claimed to have achieved very good sound. Are there any advantages to this type of approach? I think audio engineers refer to this approach as soffit mounted studio monitors but I am not sure. I would probably go three way active, and use sealed bass drivers since I would have plenty of volume to work with as I would place the baffles about 12-15 inches out from the wall and then run them floor to ceiling and side to side so the drivers had plenty of room, maybe even enough for infinite baffle bass.... Any thoughts?
Generally speakers sound better away from a wall. They sound more "airy" 😉
So I think it would be better to have the mids and tweets in a bump that stick out a ways from the wall. The bass doesn't care, and it WILL solve baffle step issues.
A reason regular speakers sound wrong pushed against wall is that they already have baffle step correction..so the bass is emphasized.
Yes. I agree that they sound better away from the wall, and yes you will compensate for baffle step if they are flush mounted. In the world of comprimise you must figure out what will work for you. there are trade-0ffs with both ways. It is cheaper to compensate for baffle step then to build a wall.
By building a false wall you will also control some room resonance problems also, that is another benefit of a false wall.
From the man himself:
Q: In your VTL box design, why is the JX92S fitted in the wide face when it is common knowledge that the box should be as narrow as possible?
A: 'Common knowledge' and scientific fact are often very different. The narrow front face is a fashion concept supported by some very questionable marketing rational. The indisputable scientific fact is that the ideal mounting for a loudspeaker is an infinitely large flat baffle and this is the concept used for all loudspeaker analyses. A wide baffle always sounds better.
Q: What are the recommended advantages of positioning loudspeakers as close to the wall as possible?
A: This positioning secures, to some extent, the advantages described in the previous question. In addition it minimises the time delayed reflections from the rear wall which contribute to confused imaging.
Q: Will placing next to a wall ruin the stereo image?
A: We cannot see any reason why this would impair imaging. Possibly more than any other manufacturer, we have concerned ourselves with accurate and stable imaging and certainly would not promote a design that would impair this.
http://www.ejjordan.co.uk/faq.html#faq16
The reason wall-mounted speakers might sound bad is because they were designed to be placed out in the room, or because there's a load of crizznap between the speakers, which is what most people do with their hi-fi. Speakers wall-mounted on a large wall are projecting directly into half-space, with no reflections from the wall.
What seems weird, to me, are the people who have dedicated media rooms, place the speakers away from the wall, and then do everything they can to treat the back wall!
Greggo said:
I am thinking about building a false wall,...about 15 x 17 in size...about 12-15 inches out from the wall and then run them floor to ceiling and side to side so the drivers had plenty of room, maybe even enough for infinite baffle bass.... Any thoughts?
lets assume a 8 ft ceiling. and lets assume you build the wall allongthe narrow side of the room (15 ft). 4 8x4 sheets of 19-25mm marine grade ply wood would be the baffle.
your wall will encolse a box of about 15x8x1 = 120 cu. ft. do you need that volume. I would recommend that the wall only be 6" deep with the are immediately behind the woofer well damped. You could use 2"x6" beams of wood to brace the box. First attach these to the rear wall and then add the baffle.
even with a 6" wall you will have a huge box. With such a wall about 1/5 of the box volume will be taken up by bracing. Net box volume will be about 45-50 cu. ft. Should be enough for the most demanding woofer install.
Why not go all the way and build a studio monitor type speaker? You might want to recess the inner side of the "speakers" and angle the "baffle" in a little bit (and use a more directive speaker while you're at it like something along the lines of Gedde's Summa) or a nice co-ax? Common sense audio will oversell you a little P.Audio co-ax that might do the trick nicely for not too much money, though I would not try the single capacitor crossover they recommend becasue I feel it misses out on the potential of the drive units. The usual italian and french suspects also have nice co-axes (so do Radian and Tannoy might also have a suitable ceiling speaker)
Hi Greggo,
I tend to agree with B4. Building a wall is a big undertaking and will likely create as many problems as it solves.
Soffit advantages: No baffle step. Fewer diffraction issues.
Soffit disadvantages: Room modes. Wall resonances.
Soffit mounted studio monitors are usually decoupled from the supporting wall in order not to excite the wall. The supporting wall is made very solid often with a concrete cubby hole for the monitor. That takes care of the wall resonances. Imagine the problems with baffle resonances multiplied by the size of the wall.
Studios are designed by professional acousticians who have the knowledge, experience and tools to accurately predict the major room modes. The rest of us have to make do with simpler tools and experimentation. With freestanding speakers you have much more control over room modes.
Baffle step isn't such a big problem. It can be equalised out fairly easily.
Diffraction is a hot topic. Personally I don't feel it has as large an effect on the overall speaker sound as other factors. In particularly I try to control directivity to minimise illuminating the baffle at higher frequencies thus side stepping the problem to a large degree.
So in a domestic situation I would strongly advocate free standing speakers.
Ralph.
The compromize ito what it allows you to get away with WAF is another factor to considder and the baffle has to be decoupled from the speakers (a book on studio design would be my 1st move)
Diffraction is indeed a hot topic and not because of the lobing and the baffle step but becasue of the time-delayed (non-minimum phase component) more strongly localizing the speaker. I would probably treat the terminus of a co-ax with foam and watch carefully what the measurements show (you can see the harmonic structure of the diffraction caused ripple on FR plots)
just my 2c of course
Yes, this is what I've been thinking as well. I believe that may be why very narrow baffles are preferred by many, the delay of the diffracted sound being much less than with a wider baffle. This is an almost opposite view to the position in the Jordan FAQ, quoted above. Rounded or angled baffle edges help a lot though.
Softit mounting means fewer diffraction problems, 3-5dB of bass sensitivity over free-standing speakers, you don't need your speakers to be 4' off the front-wall...
The bass increase is a big one, IMO, especially if you're going to use a closed box. You should have 3-6dB to play with using a Linkwitz transform to get some extra bass extension if you want.
Yes it's a fantasic way to go! Imaging and soundstaging is excellent when done right - I have been listening to angled, large wall size baffled, 15" coaxials for a while now and diffraction is less of a problem then the traditional little 'studio monitor' out in the room type speaker. The increase in bass sensitivity is real, and with the right situation can be very smooth and powerful. The actual sonic illusion can be quite good also because if you build them in and 'hide' them there is no goofy boxes out in the room pointing at you saying ' listen to me' I'm a speaker -
@ azrix: A sufficient roundover is large, generally more than what some might call a super-narrow baffle if you really want to tackle diffraction properly. I tend to think of a dome on a baffle as a poorly terminated 180 degree waveguide.
if we brace the wall well enough we can reduce resonances. I like the idea of the huge volume in such a wall esp to conceal subwoofers.
also some speakers are designed to work best placed flat against the rear wall. most of these have wide baffle and are not deep. maybe this is a solution.
Actually, I was thinking about same thing. My idea was to start with some good wide-range mid-bass crossed around 100Hz and as much possible high... say 5-6kHz. Still not sure about drivers, but scan speak relevator looks nice for tweeter...😕
Yes, interesting.... But, drivers like Jordan need some serious implementation. When they go up the piston motion of the cone cannot keep up with a voice coil anymore, resulting in breakups. Those breakups result in a harsh metal sound they accused for. Yes, that can be solved with bit more complex crossover and added filters, but then I'm afraid this can be never-ending story without serious measuring equipment.
About "super tweeter" mentioned in combination with Jordan's I can tell that is interesting (price), but nothing more. Not sure about car speaker in recording studio environment😕 I still believe that we can figure something more interesting....:hot:
Thanks for all the replies, good stuff that has led me to my latest thoughts (not that I expect you to care, but just in case you are bored and feel like reading what I am having fun writing...):
1) Building a false wall is too risky without acoustic modeling tools/knowledge base that the studio guys have since my room may change over time and I don't want to be trapped with a design that falls short of expectations when fully implemented, and prototypes would just be too much effort in this situation
2) I still like the idea so I am going to go with giganctic speaker cabinets that are in essence small movable walls, heavily braced and damped construction methods, something around 48" wide by 78" tall (a golden ratio baffle) and between 12" and 18" deep, and about the same space between them and the backwall is what I would probably use as part of the design guidelines...
3) I am very tempted to go open baffle for the woofers, but don't like all the drivers required for real SPL down low and since I would need to place these close to the back wall given their huge size, I would go with a single high quality sub in a sealed cabinet.
4) Leaning towards a small line array for mids and tweets in order to have as dynamic a system as possible, attempting to bridge the gap between "pro sound" and "hifi" driver characteristics while improving the size of the "sweet spot", the more I think about arrays the more they make sense but the cost of quality drivers in such a configuration sure is painfull...
5) Would have the cabinet somewhat resemble a wing shape, with the outer sides of the cabinet holding the woofers and being roughly 15 inches deep and then slowly tapering to the inside edges which would be roughly 5 inches deep, both ends being as fully rounded as possible, and tops and bottoms of the cabinet being straight to minimize woodworking headaches. Also, the vast majority of the baffle would be a flat surface, with tapering and rounding only happening at the ends...
6) A reference prototype I am thinking of funding this spring would be:
a) A rythmik audio 12" servo sub built in just to the outside of the center of the baffle (running 20-60 Hz)
b) A seas L26RFX/P 10" woofer, one just above and one just below the sub (running 60-300 Hz)
c) An array of 4-12 (depending on budget) Jordan JX53 lined up between the center and the inside edge of the baffle, still giving them plenty of baffle space to open up and sing before any diffraction effects start to interfere, running from 300-20,000 Hz
d) Digital active crossovers, plate amp for the sub, Pass DIY amps for the rest.
I think this is my official dream system, one has to dream after all...
*** Oh, and I should add that all these drivers are aluminum, and keeping the cone material consistent should help in blending them together, and since the front and back baffle slope inward towards each other as one moves from the outside edge of the cabinet to the inside edge, I should come fairly close to physically time aligning the drivers, but will probably still need to make a few small timing adjustments with the digital crossover...
Man, my wife is gonna kill me because I think I am going to have to skip the premission step and just go straight to ordering stuff with my VISA card...
