It's pretty simple really...there are 8 (or 9, maybe 10) planets orbiting the Sun and a few dozen natural satellites orbiting those planets. All of them (including the Sun) except the very tiniest are quite spherical allowing for some rotational bulging at the equator. The gravity of large astronomical bodies has only one stable solution...the sphere!
Also, long flights on airliners do provide rather direct evidence. In the many times I flew from Detroit to Japan, China or South Korea back when I was a working slog the route flew pretty much straight north from Detroit (often with a view of the Mackinac Bridge) then across Canada and northern Alaska (plenty of snow on summer flights) and down the east side of Asia. What rational airline would burn fuel flying north for hours from Detroit (latitude 42 degrees) crossing 10 degrees latitude to reach destinations whose latitude is only modestly north of Detroit at mid-30s degrees.
While we're at it why does it take nearly as long to fly from the West Coast of the USA to these destinations as it does from Detroit. There are topics where serious people can debate our understanding of science, physics, astrophysics, etc...whether the Earth is (nearly) spherical isn't one of them.
Indeed, good point. Unless, of course, it is also part of the global conspiracy and subsidized by the Illuminati. You never know 😱
Jan
https://www.youtube.com/watch?v=9dMpX7WUIlUThere are topics where serious people can debate our understanding of science, physics, astrophysics, etc...whether the Earth is (nearly) spherical isn't one of them.
Jan
That was funny Jan ..... next up reptilians and the Hollow Earth 😉
Well that was easy. See Flat Earth map below.In the many times I flew from Detroit to Japan, China or South Korea back when I was a working slog the route flew pretty much straight north from Detroit (often with a view of the Mackinac Bridge) then across Canada and northern Alaska (plenty of snow on summer flights) and down the east side of Asia. What rational airline would burn fuel flying north for hours from Detroit (latitude 42 degrees) crossing 10 degrees latitude to reach destinations whose latitude is only modestly north of Detroit at mid-30s degrees.
Anything else I can help you with? 😀
It's a well established fact that the uk royals are actually shape shifting lizards...
So's Miley Cyrus the evidence is on You Tube what more proof do you need 😉
I don't get it...Australia appears to be twice the size of the USA on that map, did someone make a mistake when they measured it?
That is correct, it's a polar projection of a globe - labeled as a flat earth map. A good flat Earth map will have those continent shapes corrected. I have one somewhere, will try to dig it up.
Doesn't matter for the Detroit to Seoul flight, tho.
Nice...the North Pole at the equator doesn't create any inconsistencies? Oh and how exactly do the longer and shorter days at high latitudes work with this geography? Oh that's right...it only needs to answer the flight path questions and a holistic picture that explains all observations isn't required.
It can't be flat AND spin surely else I would have been flung off when I was in Melbourne a few years ago? 😕
90% of the matter is obscure and that might cause some alarm ( to be not able to go through it ). If you think well, you don't like boiled potato, you want fried tortilla !
Wow, you really haven't been following along, have you? 😉Nice...the North Pole at the equator doesn't create any inconsistencies? Oh and how exactly do the longer and shorter days at high latitudes work with this geography?
.....and i thought only psychology doctor, who has medicine degree can measure patient intelligence. Something tells me that this is not your case.🙄Why bother debating with idiots? Just ignore them, plenty of crack-pot theories out there, so many stupid, stupid people! 😕
It´s today fashion to hide behind internet, and flex muscles..
- Member Areas
- The Lounge
- Flat Earthers
