I can't see from where you are (and my memory is extremely selective)
it can be handy to have that info in profile
send me PM
I'll send you matched J271
don't have too much 2SJ74, but these will do ....... they were good enough for Babelfish J
I know that J309 is lower grade of J310
from top of my head , same with 270 and 271
though, Idss range not exactly important (especially if higher) when JFets are externally biased ........ as here is the case - LTP is fed with CCS
no way, GR having muuuuuch lower range of Idss than is the case with any 271
luck with JFets - you have luck either buying them matched ............. or buying them in quantity, so you have a pool for matching
do not even think, ever, in numbers lesser than 50pcs
- FirstWatt J2 with mosfet input a la Aleph M possible?
