I thought on page 7 Papa suggesting some values to play with. I have not used my measurement mic in a while. Wondering if those values are near the ones to use in a bass reflex design with Fostex drivers. FF165K specifically .
aha , now you clarified ........ you want to use just EQ network (shown as R0,L0,R1,C1,L1 in simulation model)
partially mea culpa , though just now I finished first morning coffee , so not entirely to blame me
yeah , you got it right , there is practical info , but if you want to change box vs. what's given in recipe table on p.7 , you'll need to fire up measuring jig
Yup ZM. But the statement still hold true ? the BSC net work is independent cell and EQ network is not going to affect it?
pretty much like that
we know what BSC cell is addressing , while we are assuming that EQ is addressing other part of spectra
I had assumed they were more. Nice.
No problem, just keep asking questions. This forum, it's people, digital pics are better than a kit.
Russellc
Can anyone recommend the total cap per rail for the M2? I'm using the Universal PSU from the store. I've seen 60,88 and 108 per rail?
common PSU or mono PSU?
Pa is using 8x15mF (CRC arrangement) for common one , and nothing stops you in using more
Common Psu. I don't think I have room for mono. Thanks.
Everything you need to know about the power supply.
diyAudio Power Supply Circuit Board v3 illustrated build guide
Is the universal power supply compatible with teabag's M2 boards?
Yes that is what I'm using. Here is what I'm using for reference to build mine:
First Watt Clone - The DIY M2 - Solid State - The Klipsch Audio Community
Thanks, I can't find the parts number for the two bridge rectifiers between the tranny and the boards.. I get that than I think I'm Gucci.
Study the build guides for First Watt amps put together by 6L6. You will learn all sorts of tips from them. They all have the same basic power supply, so all the amp guides are useful there. Also for how things go together, wiring, parts choices etc. The only thing that is a complete kit are the Amp Camp kits.
Fear not, not that hard really.
Russellc
Okay so I received the universal PSU yesterday. After reading several posts, I can use the diode section on the PSU Board or I can go with Bridge rectifiers. Some cases don't have the space but Which one is better for audio fidelity reasons?
- First watt choices
