first time winISD use - would you please check?
Hello,
I read the winISD manual and tried to simulate the response with below specifications:
Pioneer TS-W126M driver specs: TS-W126M | Pioneer
What I used inside the program as parameters are attached.
For the box, I used ported 200 liters with 18hz tuning freq.
For the filter, I selected highpass / butterworth / 18hz.
When/if you have a chance would you please check whether I did insert the parameters correctly and the output matches what you produce?
Also, do you recommend this driver for a smallish room (15 m2 area, 35 m3 volume)? Since it is cheap (around $38 including shipping) I am planning to purchase it for my first home theater subwoofer.
My other choices are JBL CS1214 ($50) and Pioneer TS-W311D4 ($63) (or second hand infinity 1260w - $55).
Best,
Thank you for the replies.
I have been reading more and playing with the winISD. I believe I am in between two drivers: Infinity 1260w and JBL GT5-12.
I have created profiles for them and compared with each other (as can be seen in the attachment). Several questions that come to my mind are:
1) Which one is important: curve smoothness of transfer function magnitude or SPL function? What are the threshold values (such as 2 dB's or whatever the value) to say one is statistically or hearing wise better/worse than the other?
2) Due to room limitations I am planning to use either one (preferably) or two subwoofers and I believe at most I can make a cube of 55 cm in outer dimensions (5.86 cubic feet or 166 liters). Do you think, as a rough estimate, it can provide at least 140 liters inside?
3) I also attached JBL and Infinity tech specs. When I insert infinity specs to winISD, I am getting same results with auto-calculation option. But, I believe there is a discrepancy between what winISD calculates and the JBL tech sheet. When I insert Mms and Cms (223 grams and 135 um/N) winISD calculates the Qes and Qts as 0.704 and 0.634, respectively;however, tech specs indicate that their values are 0.64 and 0.58. Do you know which ones should be correct?
4) Which one should I buy 😕
Best,
EDIT: third attachment is for infinity and fourth is jbl (forgot to legend them).
  • REF1260W.pdf
    REF1260W.pdf
  • JBL_GT5-12.pdf
    JBL_GT5-12.pdf
Hello again,
As suggested, I bought two infinity reference series 1260w subwoofers along with a 90-liter box for car use (came with the deal) for $95.
Even though I didn't live test them, the ohmmeter and the sound of cones suggested that they are fine.
Now, I have another dilemma. Since power amplifiers are expensive here, after a lot of research I am planning to buy a second hand "Audio System Twister F2 300" car amplifier for $100.
It is Italian made and can provide 780W RMS in 2-ohm bridged mode. It has also a high pass and low pass filter down to 20Hz. The specifications can be found in the attachment.
I am also planning to get a custom made converter of "220V AC" to "12V DC 60A" for $40. Do you think it is overkill?
Do you recommend this solution or should I invest in a power amplifier with a built-in DSP (such as behringer NU1000DSP - can get for $250)?
Thank you.
Hello again and thank you for your opinions. I also would like to get the inuke however my budget is limited and found an older behringer ep2500 for $120.
Probably it is going to be a better alternative than a car amp + AC-DC converter and it is half price of the inuke1000dsp. Now I am thinking to get the ep2500 and try to adjust the bass response with acoustical treatment rather than equalizer and/or filters. What do you think?
Best,
EDIT: I believe I can use the sp2500 in stereo mode (650W @4ohm) or should I use the bridged mono mode for two infinity 1260w's? I read conflicting posts regarding "stereo", "parallel" and "bridged" connections and settings... I would definitely want to have same signals going to both subwoofers.
Or go for the non-DSP version of the iNuke. Maybe your HT receiver can do the filtering and DSP'ing for you (it might have Audyssey or equivalent). A high-pass filter is recommended to save the woofer from excessive excursion, so an amp with some filter settings is probably a good idea.
One more thing I wanted to ask.
I read that if I can't lift the LFE output of my AVR (a 11 year-old denon 987) enough, I am unlikely to drive the EP2500 to full power and will get unsatisfactory results.
Is there a way to learn whether my AVR sub out would be good enough (at least until I get a newer model)?
Note: I read 4real's response while typing, my AVR has a small microphone for auddysey setup.
Hi again,
I think I will be buying the nu1000dsp but have some suspicions in my mind.
Based on the manufacturer ratings and third party reviews on these units it can deliver perhaps around 70% of its rated maximum output power, which means around 450W RMS (in 8 ohm bridged mode, subwoofers in series). Would it be sufficient to drive 2 infinity 1260w's (rated 300W RMS each)?
My other question would be whether the nu1000dsp's are 2 ohm stable in bridged mode and what would be the RMS rating? Perhaps I can wire the subwoofers in parallel.
Thanks!
