Wish me luck chaps, after building some lovely amps last year (GB150 kit not my design!) I am just starting my first ever speaker build. After much lurking I decided to build the PAWO with FE127E drivers. I am building out of baltic ply and so far have the pieces cut oversize for the speakers. Today I am going to start marking up and trimming to size.
Any general tips for my build?
I plan to:
Measure, measure and measure again on each piece.
Clamp everything with as many clamps as possible!
I plan to do the front last as I have never even used a router before so I need to practice on some scrap. Should the driver be recessed for this build and if so how on earth do I recess the shape of the driver as it's not round
Any tips would be greatly appreciated, I think I have read all the info on the PAWO I can find on here but simple pointers are always appreciated.
Cheers
Iain
p.s. Actually I am doing 2 builds I have some CSS125's as well which are not supposed to work that well in these but I am going to make them both and have listen.
I plan to:
Cheers
Iain
loninappleton said:At this stage of the game, I'd check the table saw for square and sharp blade. The piece should touch the same on the front side of the blade as the exit side plus checking for vertical.
Nice tip, I've been using some old bits of wood to cut used to using it as I've never done this before and I am not 100% convinced it is a square cut at the moment. Will try and tweak it
Iain
Same point as me then, mine are all glued as well. I am not sure about paint. My buring questions are:
1. What is the best type of damping to use in the chamber, a lot seems pretty thick and there is not mush space in there.
2. Do I need to seal the inside in some way? Mine are in baltic birch ply.
3. Do I need to fit the drivers flush or where can I get a supra baffle like the lovely one on somebody has round here, planet10 site has the pics.
I must upload some pics, what have you built yours in?
Iain
Iain
Thanks, any thoughts on the bitumen type damping? Looks like an easy thing to apply. It's a strange requirement but I have a worry that if the cats bring a mouse in it could take up residence in the speaker, felt is probably comfy but bitumen would put them off!
Cheers
Iain
Cheers
Iain
iihay said:3. Do I need to fit the drivers flush or where can I get a supra baffle like the lovely one on somebody has round here, planet10 site has the pics.
The boxes will be better if you flush mount. Even better if you flush mount on the supraBaffle (the extra inch of depth really seems to open up the midrange (or it could be superior wave launch).
dave
dave
Excellent, thanks. I love the look of the supra baffle on those gorgeous bamboo ones you made. Can't aspire to that on a first build though but some kind of supra baffle would certainly look good and if it helps the sound that is they way I shall go.
Cheers
Iain
Hi Iain,
Have you tested your Pawo? How It sound?.
I tested it without the baffle, using solid state JLH-Class A. The vocal is excellence. Mid bass is very good too. But the lower bass is not strong enough.
I have just tested my Fonken Mk-II. If compare to Pawo design, MKII have more bass and more dinamik. The vocal sound good too but not live-ly as pawo.
what you think?
what you think?
Not finished yet, I blew a channel on my amp which has been occupying my time. Hope to get to listen to them at the weekend. If the lower bass is lacking maybe a sub build is needed
Encouraged by your post, good vocals are what I am seeking at the moment. Have you tried this with any classical stuff?
Iain
Iain
Any advice on the damping for these. I have put some across the back of the chamber, do I need to do the sides of the chamber as well?
I did try and view the prototype pics from the link on planet-ten but they're dead at the moment. It looks like some is on teh sides. Hoping to get a listen this weekend
Iain
Iain
- Full Range
- First time build PAWO FE127E
