Feedback and Gain
Hello everyone, is there a 'simple' way to calculate gain changes with alterations in a feedback circuit?
I have an old Sp8 circuit that takes feedback from through two resistors, one of which is optional to remove for a 10 dB alteration according to the manual. I was wondering if I could reduce by a little less e.g. 5 dB by altering this resistor as opposed to removal.
ARCDB is here (last 3 pages are the circuit I have) and there is a note 5. on the circuit diagram about resistor R27 removal for 10 dB gain.
I have also interpreted that more feedback = worse sound, so want to be careful about how much to temper a very high gain preamp with very sensitive speakers. (It still hums a little too much on standby, and I don't use much of the volume know for full listening levels)
The link is a bit broken, but the relevant part of the circuit is attached. That circuit relies on feedback, with the output cathode follower sharing a resistor with the first stage cathode. I wouldn't be worried about "more feedback = worse sound" in this case. Just try the suggested modification, or if you really only want 5 dB gain reduction then try replacing R27 with an 8.2k (bit of a guesstimate but should be close enough).
attachment.php
I haven't, the SP-8 that I have here is supposed to be repaired and sold, and I'm not sure the new owner would appreciate the mods.
Getting rid of the timer circuit and line voltage muting circuit doesn't seem like such a bad idea though, how's the turn-on thump with the LDRs pulled out?
I purchased some more optocouplers as they are no longer in production and not that expensive from the US to have on hand, in case I wanted to sell the sp8 in the future and someone wanted to have an original even if it sounded worse...
I just put the manual mute on and wait 2-3 mins, then play as normal. What is an LDR not sure what you mean here?
yeah it is, when the mute timer is complete it acts as a short circuit, and when its in warm up it acts as a high resistance, but mine were tired (bit noisy in warm up) and now out of circui: way better quality of sound. I swapped out a resistor to make this work, so this may have also improved the Sound?
Thanks - have got the photo sorted now.
The other sideways approach could be to somehow reduce the sensitivity of the power amplifier with a volume pot at the input or resistance change here / or maybe shunt in someway the output to the speakers. Is this a possibility or a stupid idea to spoil sound quality?
I think PPR answered your question the gain is roughly R83 / (R27||R28) as this determines the NF. R83 sets most of the current in the cathode follower, but you can vary R27||R28 as the first stage bias floats and R23 sets the current here. Very cleaver circuit avoiding two coupling caps.
Thanks for the advice, and on a similar principle - a friend of mine has an SP10 which is very similar in that it produces 26 dB gain on line stage, it does have a high gain/low gain switch - but sadly looses quality on low gain. He is trialing a different power amp, and the supplier has loaned him an integrated so that he can see both the power amp side and the pre amp; for the power amp he just runs the SP10 into a line input and controls effectively 2 volume knobs to balance the Sp10 to be around 11-12 oclock. SO the question is could he just fit a voltage divider as an attenuator into his normal sensitivity amp. He does not want to change the inside of his amplifier with gain settings.
