HF is not a strong acid in water. pKa is about 3.2.
If you want it to be strong, it needs to be dissolved in SbF5.
Mentioned earlier that copper and steel wool are matched remarkably well, easy to get over 50dB null when differencing, if a particular short section, that looks nominally poor, is fine tuned in amplitude then an over 60dB null is possible -- and there is a overall trend of nearly 70dB null. Yet to my ears there is a subtle, very subtle difference in quality between the two, I got them back to front in fact in the guessing - so might do a bit more fiddling, to try to understand what my ears are picking up ...
Thanks Frank. I'm going to try some more tests and hope for better results. I may try a firewire interface like one of the Presonus digital consoles we have at work. It should be glitch free.
I'm still debating about going balanced. A balanced circuit should pick up only the difference signal in the 2 wires, so that would help kill noise. But if the material under test (brass, copper, mud, banana, etc) has an effect, it should be the same effect on both wires of the balanced circuit - and therefore cancel itself out! 😀 I don't really want to do that.
You're telling us that hydrofluoric acid is not a conductor?
I think he was saying don't put your interconnects in it or they will dissolve 😛
Tony.
Indeed! But maybe they just shorted out in the acid when both shield and center were laid bare. 😉
That article appears to make at least two mistakes, which may be sufficient to render its conclusions invalid:
1. failure to distinguish between phase and group velocity - his speed calculations look suspiciously low,
2. failure to recognise that the 'energy storage' is simply internal inductance.
Hawksford seems to have a knack for writing articles which look impressive and 'scientific' yet his arguments often don't hold water.
His speed calcs are based on planar wave propagation into metal normal to the surface.
He also swapped in magnetic steel wire when he did the scope test, but neglected it's mu when looking at the results.
jn
Has Hawksford written any sound articles, with good physics and good maths? I'm sure he must have, but the ones mentioned on here always seem to be the dodgy ones.
Or perhaps the electrodes were dissolved?You're telling us that hydrofluoric acid is not a conductor?
Yes. A lot of his signal processing stuff is , from what I understand, quite good.Has Hawksford written any sound articles, with good physics and good maths? I'm sure he must have, but the ones mentioned on here always seem to be the dodgy ones.
I agree, his early article on wire signal prop is indeed "dodgy".
jn
Malkolms message is simple :
The skin depth in copper at 20kHz is ca. 0.5mm.
So if you do not want skin effect in the audible range your individual isolated cable strings should be smaller in diameter then 0.5mm.
That does not imply that your speaker cable should be that small but instead could be made of several individual insulated strings ( aka. litz wire ).
He advocates solid core out of reasons that are not so obvious at first glance.
One is "core jumping " between non isolated strings and there are mechanical issues in non solid cores like magnetostriction.
I just can not see why this is unreasonable.
At least he is a professor and won the AES medal in silver for outstanding contribution.
It's not unreasonable, it's just wrong. There's about an umpty-zillion posts here explaining very carefully why it's wrong and the experimental evidence that contradicted his assertions.
His paper went WAY beyond skin depth (which has also been quantified and found to be lacking) and he postulated echos of the sort that would make your computer and the internet impossible. Ooops.
Sorry, please show me the passages.
I agree in one point :
Inductance mostly swaps skin effect.
Search the Curl thread. Just as easy for you as for me. 😀
I think there were also numerous posts in several speaker cable threads, as well.
Yeah, but did you listen to the files?
(A new batch is coming with a better DA/AD loop and better shielding.) Still betting no one can tell copper from steel wool from mud.
I would suggest doing 2 runs with the copper: as the first test, and then the last test, Copper 1 and Copper 2. It would be interesting to see how consistent they are with each other, and how that compares with the steel wool and mud.
- General Interest
- Everything Else
- Fancy Interconnects? How about a potato, or even mud?
