Fake small signal transistors?
... I found kits with typical used transistors on Ebay/Banggood for almost no money. But I am worried they are fakes, because almost all transistors have the same datecode/batchno "331" even when they are very different types.
I stress "tested" some "331" marked 2N3906 from an AliExpress assortment kit, against U.S. made 2N3906, obtained from reputable supply sources, in a badly made switch that basically let the device draw unlimited current until it failed. The U.S. transistors instantly failed, sometimes spectacularly exploding. The "331" devices could hang in for a second or so, sometimes a bit longer, before failing gracefully, usually with just a cracked case, although one let out an impressive plume of noxious smoke for several seconds.
I also had and tested some smd SOT-23 '3906 parts from another AliExpress assortment kit, that are probably also "331", and these seem at least as good as the U.S. parts for a switch application.
I think these assortment kit parts are probably okay for hobby type use.
That is interesting. To me it proves those two groups are different because they behave differently.
However, transistors failing sooner does not mean they are worse or of lesser parameters. It may mean they are less current limiting, draw more current and self destruct sooner.
They likely are just using a smaller die - which means they will not handle the current - if you buy from a known company you are less likely to get bad parts. I've been buying parts since the late 80's and I have been on Ebay since 1998 selling parts that I obtained when Xytec went out of business, and over the years I have seen a lot of sellers come and go and no clue how these sellers with 240 negatives a month can even be on Ebay - I have 100% rating..
....It seems akin to counterfeiting pennies.
There was a guy who set up to counterfeit nickels. If you make a lot of them it looks like real money. Nobody actually looks at nickels. And this was days when cigarette machines and jukeboxes took coins, so banks were used to operators coming in with large bags of coins.
His main mistake was to order the *exact* alloy the Mint used. Someone thought that was odd and went to his house to see what he was doing. In retrospect he cudda used a similar alloy-- his fakes did not have to look beautiful forever. OTOH Henning made hundreds of thousands of bad nickels, today widely available $5-$15 (so worth more than most $0.05 pieces).
There's also a thing for stamping an "S" to make a common 1924 Buffalo into a San Francisco Mint buffalo (I think I got that right).
____________________________
Brooklyn Woman Finds Counterfeit Penny Made of Gold - The New York Times
"Brooklyn Woman Finds Counterfeit Penny Made of Gold
A “penny” made by a Seattle artist out of 18-karat gold was put into circulation in Los Angeles in 2007 and found by a graphic designer in Brooklyn two years laer.
One afternoon in March 2007, Jack Daws stepped up to a newsstand in Los Angeles International Airport with a handful of change, including a counterfeit penny made of 18-karat gold that Mr. Daws, a Seattle artist, had fashioned. He carefully put the counterfeit penny, dated 1970, down on the counter, counted out enough change to pay $11.90 for a Hustler magazine and left.
...when Ms. Reed was paying for groceries at the C-Town supermarket in Greenpoint, she noticed the penny because the gold color had started to peek through."
The question of counterfeiting nickels is do they cost more than 5 cents to make? My guess is they cost about a buck apiece unless you really *are* making a gazillion of them. And the exact alloy the mint used would have some sort of premium attached to the price tag.
“Captain, I must have some platinum. A smack block - five or six pounds...”
Dün 2N5551/2N5401 aldım ve ödemesini yaptım. Muhtemelen ocak ayında burada olurlar. Ekli resme bakın (Ebay'den)
İlk başta çoğu üreticinin daha çok smd'ye geçtiği için eski stoklarını en yaygın parçalar için boşaltmak isteyebileceklerini düşündüm. muhtemelen burada yanılıyorum🙂
Bir yan not, ancak ilgili:
Gülmek için bu bağlantıya bakın. Batık güç transistörleri için. Bir set için 2,60$'dan çok ucuz bir fiyat!. Ancak aşağı kaydırırsanız, şunu söyleyen kırmızı bir not göreceksiniz:
1 çift VEYA 2 ADET Transistör SANKEN MT-200 2SA1295-Y/2SC3264-Y 2SA1295/2SC3264
Önemli uyarı: Bu ürünler Japonya'da değil Çin'de yapılmıştır. Japonya'da üretilen yüksek kaliteli ürünlere ihtiyacınız varsa. Gereksinimlerinize uymuyorlar. Bu durumda onları satın almayın veya kabul etmiyoruz. iade ve geri ödeme.
Ve bu okuma notunun hemen altında şöyle yazıyor:
1. Büyük stok bileşenleri ile kendi deposu, %100 orijinal.
2. En iyi kalite ve En iyi fiyat
1 çift VEYA 2 ADET Transistör SANKEN MT-200 2SA1295-Y/2SC3264-Y 2SA1295/2SC3264 | eBay
Bilerek sahte sattıklarını bildirmeli mi?
Hi everyone.
I thought I'd pick up some misc small signals for repairs and playing around. I found kits with typical used transistors on Ebay/Banggood for almost no money.
But I am worried they are fakes, because almost all transistors have the same datecode/batchno "331" even when they are very different types. Also, i do not see any manufactorer markings.
I bought some 2n5551/2n5401 that also have this same marking. Unfortunately I noticed this too late.
Should I be worried, or is there an explanation for this. Please see the attached picture ( from banggood )
Jørgen
ONSEMI 2n5401 2n5551 original
