Faital 6FE100 TL
Hi there!
A question, why I ended up with a 43Hz tuning instead of 63Hz as calculated?
Line not filled but lined with 1" thick noise reduction felt
I made an extremely rough and ready simulation of what you have made.
It's advised that it is best, especially with TLs, to simulate before building.
It roughly correlates with what you have.
A bit late to the thread, but since it hasn't been mentioned, your TL tuned lower than its length suggests because it tapers down and has a restricted terminus. The opposite holds; an expanding line will tune higher than the linear QW frequency, unless its terminus is restricted.
What did you end-up doing to these speakers?
I'm not alone then, to have measured the 6FE100 with differing parameters versus the spec sheet. Here's one of my pair below, the other being similar enough.
Thiele-Small parameters
fs 90.3 Hz
Qms 8.039
Qes 1.000
Qts 0.889
Fts 101.5
Mms 12.92 g
Cms 0.241 mm/N
Rms 0.911 kg/s
Vas 6.98 litres
Bl 6.329 Tm
Eta 0.50 %
Lp (1W/1m) 89.15 dB
Dd 13.49 cm
Sd 142.9 cm^2
Cms is half what the spec sheet states (0.48 mm/N). You are right in saying they can take a lot of power though. 🙂
My pair sits in a single 21L sealed enclosure (monophonic) in my garage/shop. With stuffing, Qtc is a bit above 1.0 and it sounds pretty decent. IMO, a slightly longer TL with a fair bit of lining and stuffing might be good for them.
Hi, I'm using them: Dell laptop Topping DX3 DAC Proton AM2 amp, with a moderate eq down the 150Hz zone exces. I use measured specs, not the factory advertised, see attachment.
Can I see the schematic of the crossover?
sure thing: Just R3 is after C3 in the actual build
Yes, tapered TL tuning is lower than based on length alone, but is the tapered TL is best for nice tight bass. You can adjust stuffing to bring peaks down and this will reduce group delay. Too much and it sounds dead. The impedance sweep is the way to check though. 45Hz is a nice spot if you can deal with the baffle step loss. You will have to drop system efficiency quite a bit to match the treble with the bass.
FYI/FWIW, IME and proved to my satisfaction when 'proofing' MJK's MathCad design programs against some of my own Tower/Column alignments from 'way back when', the vented TL [closed pipe] alignment [aka MLTL] range from ~0.312 - 0.624 Qts' seems technically good enough, i.e. from Keele's 6th order assisted bass reflex to his Extended Bass Shelf [EBS] alignment.
While the 'sweet spot' [mean] is a ~0.4412 Qts', a 'close enough' simple guideline is:
~0.403, Vb = Vas, Fb = Fs [MLTL]
< ~0.403, Vb = < Vas, Fb = > Fs [inverse tapered MLTQWT]
~0.403, Vb = > Vas, Fb = < Fs [expanding taper MLTQWT/MLhorn]
Qts' = Qts + any added series resistance [Rs]: http://www.mh-audio.nl/Calculators/newqts.html
Thanks!
I know, but I do prefer to preserve the 90 /88 dB level and eq down the 150 Hz excess via signal modification. Any other eq is embedded in the filter, that deviates from the textbook Butterworth 2nd and 3th order for this very reason.
