Failing EL34 tube in push-pull blowing fuses?
Oh just found a faulty diode on EL34 screen, this has a resistance of 6 Ohms in either direction… but does not explain the path to ground (fuse blowing) when no tubes are inserted. I have some components arriving this week. Will start to investigate…
What diode is connected to an EL34 Screen?
Post # 1 schematic does not show any diode, it shows a 1k screen resistor.
Please post a real schematic.
Without that, we are like a blindfolded archer shooting at the target (after having been spun around an unknown fractional number of turns).
Having an accurate schematic will help with todays problems.
And it will help prevent future problems, and help if there are any in the future.
tc 60 re issue amp
hi there
ive just come acros this post regarding this amp - i have the same !! 2 x el34 and 2 x 12ax7 - ive got red plating going on and found a pretty charcoal'd resistor - i really need a schematic for this bloomin thing -- did you ever have any luck ??? theres nothing i can find anywhere
Chris 😡
Hi Dan
thanks so much for replying
my pcb is v:1.2 -- TC60XXD01 - You got further with carlsbro than i ever managed , also if you have the amp still - would you know the resistor on pcb edge around the p10 and p9 supplies - thats whats frazzled and i cant begin to measure it - this thing could end up in the bin !! Chris
Here is the version 2 PCB from my amp when I had it on my bench.
These are the only files that they had. It’s the version 1 PCB as far as I can tell.
I’m not too sure what you mean P9 and P10, maybe because I have a different version.
  • tc60.pdf
    tc60.pdf
  • tc60-1.pdf
    tc60-1.pdf
  • tc60-2.pdf
    tc60-2.pdf
