F6 Illustrated Build Guide
I pulled the zener. Measured resistance in both directions and one was higher than the other suggesting it is OK. Other zeners i have on hand measured the same. Double checked solder connections - measured resistance between both ends of zener and the rotary pot contacts and everything seemed fine. I replaced and still getting the same issue, 24v dc on the speaker terminals.
Do I investigate the mosfet next? The odd thing is that the amp was working fine for a year and then seems to have slowly gone bad which I guess suggests a part has gone bad?
Thanks for the help.
Looks like the simple resistance test is not enough to properly test zener. I will replace zener with a similar voltage that I have on hand and see if that solves.
Yes, might need to replace all cheap parts if there are no better suggestions...
Also, I have done the output degeneration mod so the circuit is a little different than that in post 1 of this thread (might help with troubleshooting).
Hi everyone , i am about to "start" my F6 , and i made some mesurement before that :
I have 164 ohms between + and out , same resistance between - and out , and 120 ohms between 0v and out , with no supply connected on the board ,on both channel , is that ok , or may i worry !!
tanks for your help ;-)
Fabrice
Hello,
I hadn't used my F6 for a while and hooked it up over the weekend and found
one channel buzzing/distorting. When I randomly tapped the PCB and the heatsink
on the offending side with a pencil it would sometime get better.
I'm guessing there's a bad solder joint on that channel somewhere and am
thinking of removing the PCB and reflowing all solder joints.
Does that seem reasonable? Is there anything else I should look into?
Thanks,
Dennis
