Second group consist of about 8 people. Hoped to get to it today, but it will ship Monday. I will pull your kit and try to get it out Monday. We are in the home stretch here, so please continue the wonderful patience you have all shown thus far. I do appreciate it.
Got my kit!
Is anyone using Teabags boards on the pre drilled big *** chassis?
I don't want to tap holes but I also like the 1 board solution.
THe big chassis does not have the holes for the diodes, so you will have to add them to mount diodes. That being said, the big sinks can take some heat and V3 is worth a try, just keep bias low until you are sure of heat. V2 is no problema nd PKI has had his on store sinks for a while.
Putting them on the skn raises their temperature, making them conduct faster. It also makes their temperature more stable. It is your call. It certainly works fine off sink.
Got my kit!
I am in that boat, I am waiting it out while assembling/finishing my Pearl2 and a couple of other projects and see what everybody else does. If I need to get store boards too, no biggie. I've got too much invested in this to screw up and not hate myself!
Similarly, I want to wait until the build guide is complete and all issues worked out. I want to make sure the store boards are as they should be.....dont understand why, for example 6L6 build kept having stability problems while I dont remember Buzz having to install additional caps and increased resistor value....just an example of why I want the smoke to clear a little before I add mine to the cloud!
Russellc
If I do this build with the boards I have from Teabag, I will drill and tap to mount the diodes on the same sink. They are small holes, easily drilled and the tapping is also a snap. I like the idea of them conducting faster.
Russellc
It is how Nelson intended it. I believe that you can proceed with confidence in the build. I have done everything but switch the polarities on these things and yet to have issue. I have pushed it to clipping into 8ohm load with up to 10kHz square wave and no issues. You know me, Ill be buzzing around. For those who want to use Tea's boards with a 4 outputs, but dont feel comdortable with the heat, you can always drop one of the 1r resistors and bias up to about .400mV across Rs(about .4A per output device) and you will get higher gain, little more DF, and little more current capabilty. Ill be buzzing around to help😀
Thank heavens on the "I'll be buzzing around to help"!
One question, I recall you built on tea
s boards, did you also build store boards?
If you did build tea's boards, did you find the cap necessary to stabilize like 6L6 had to do on his build using the store boards? I may have this all mixed up...
Russellc
I built store boards in both V2 and V3 with 47R gate resistors and no comp cap. Pics are in the F5T build thread.
For a single TeaBag PSU, you will need 8 Mur diodes, two CL30, one CL60, and one diode bridge. How many channels you run off the PSU board is up to you, whether stereo or mono.
So for a v2 kit with PS we should have 16 Diodes?
I think I am short 8 diodes. I sent you an email.
All but about 8 kits are packed. They will all leave by this end of the week. BillyK, you are in this group. I will be contacting you about your address info. The rest will go out next week when i get back in town from a business trip. All of you have been very patient. It will soon be over and you can get to building.
did you ever sort this out?
Russellc
- Group Buys
- F5T Premium kit GB
