With rails of 32 volts, you may get 28 volts of swing, this gives you MAX 50 watts Class A with 100 watt peak.
28.3 volts peak in 4 ohm is 100 watts Class A continuous.(with sufficient dynamic bias)
Yes, of course I forgot to say into 8 ohms.
Rush
You also forgot the presence of commercial full Class A power amps, optimised for continuous output power in other than 8 ohm.
Unless you didn't know.
IN my new speakers setup, 10W will deliver 110 dB![]()
Doubt that .....🙂
Maybe not, just going by MJK worksheet. I msut admit I am not good with numbers. Should learn, but end up spending my time building stuff.
I must admit I am not good with numbers.
Buy (build) a headphone set instead.
(Hey, I got some math books in English I could Xerox for ya)
"only" 7.07 Ampere needed28.3 volts peak in 4 ohm is 100 watts Class A continuous.(with sufficient dynamic bias)
THe V3 , biased according to article, has roughly 6.4-7.2A of bias, depending on how high you bias, correct?
Yeah, pity that my heatsinks don't allow more than 5 Ampere🙂 but hey, who needs 100 Watts continuous...THe V3 , biased according to article, has roughly 6.4-7.2A of bias, depending on how high you bias, correct?
Is this to mean I am wasting my time? Are the MJK sheets wrong?
Not at all Buzz. I know Planet10 knows this stuff . Was hoping for his perspective.
Which is not equivalent to 7.07A bias level, in an F5T.
F5T has a bit of an advantage is this regard, as the diodes give it more current swing than a normal output stage. In most cases, folks F5T will be voltage limited rather than current limited, correct?
With rails of 32 volts, you may get 28 volts of swing, this gives you MAX 50 watts Class A with 100 watt peak. If you bought this amp it would be listed as a 50 watt amp. That is a lot of class A power, but less power than an 80 watt Accuphase class AB. You are lacking rail volts to get higher wattage. I suspect you will not notice any lack of power between the two amps, the class A may even sound more powerful due to better control, etc.
You would have to go to 44 volt rails to get to 100 watts average class A power and your total bias current would need to go up to 2.5 amps. That's a lot of heat for you to get rid of.
Rush
Hi Rush,
Thanks for the information.
What ?
In a standard push-pull Class A output stage, the 'bias' swing is like a string cord.
5A bias level is +5A and -5A, looking at/from the output node.
Max Class A output current is either +10A, or -10A.
In the F5T, 'bias' swing is like a string of rubber.
The T output stage has an asymmetrical behavior, due to the added diodes.
Means that 5A quiescent current level, corresponds to more than 10A peak Class A output current.
Aka, one gate opens faster than the other gate closes.
- F5 Turbo Builders Thread
