buzz. you know me😀
heatsinked man😀 i'll use 2x10.080 profiles 6"long pr side. and drive them to maximum😀
acording to latest numbers. i will get the heat spread maximum over this field🙂 so i guess i'm good🙂 only the bias will tell😀
i will however run it on a BIT higher rail voltage. +/-51V or there about🙂 and still maintain about 2.6A bias😀
daz. it's antek profiles you are thinking of?
they are made for forced air. so i don't know. the fins are a little close.
okei. have run some PSU tests now.
with 2x40V transformer. i end up with +/-50-51V supply.
(yes it is 63V caps). so. with a +/-50V supply and 1000VA pr ch. and 4x68.000uF.
the PSU is behaving very good. all seams fine..
no reason for you to be nerves😀😀😀
Yep they are the Antek ones.
I'm using them at 8" high for my F5 now biasing at 1.6A 😀
They get hot but I can put my hand on it for at least 20s 🙂
I think the last time I checked they run at 50C at 25C room temp
When you start adding the amp board to it what voltage drop do you get? 4-5V? or about 45-46V rail?
I have trid to talk my wife into using these instead of central heating. Best excuse i could come up with to make mroe amps.
Hmm so this means to get the final 50Vpk loaded, I will need about 55Vpk unloaded
which means 55V = 1.3 x 42Vsec from the transformer.
This will mean that : 50Vpk /1.414 =35.36V and solve P=V^2 /R(8ohm) I should get 156Watts?!
What about efficiency factor ....?
Are the sinks from heatsink USA more appropriate? You can order them as tall as you like.
yes. sort of. they have more spacing between the fins🙂 but they come only in raw aluminium🙂
yeah but the difference is that Antek can also custom build a case for you with their heatsinks integrated to it.
but most of the sinks are made for forced cooling🙂 thats why the spacing between the fins are so smal.
I think this is correct now. Comments?
Prms is the Watts RMS output.
I^2 = Prms/8R0
Irms = Sqrt(I^2)
Vrms = Irms * 8
Vpk = Vrms * 1.414
Vrect = Vpk + 5.6 V
Vac = 1.3 * Vrect
Loss/droop of 5.6 volts. This is Class A.
Prms I^2 Irms Vrms Vpk Vrect Vac
20 2.5 1.581 12.649 17.885 23.486 18.066
50 6.25 2.5 20 28.28 33.88 26.062
100 12.5 3.535 28.284 39.993 45.593 35.072
150 18.75 4.330 34.641 48.98 54.582 41.986
As far as the VA for each transformer, that is a different story.
Please note, I take no responsibility that these will work in your amp, as I'm just trying to learn this stuff and could be very wrong.
AudioSan,
The table suggests you are going to get 135 Watts from a 40 V transformer. In real life, a little less.
The table also suggests that 50 V caps should be OK for a 100watt amp.
I^2 = Prms/8R0
Irms = Sqrt(I^2)
Vrms = Irms * 8
Vpk = Vrms * 1.414
Vrect = Vpk + 5.6 V
Vac = 1.3 * Vrect
AudioSan,
Personally, I think your first equation is Irms^2= Prms/8R0,
But this is backwards???
SqRt (Irms^2) *1.414=Ipk
Ipk*8R0=Vpk
Vpk+(2V MOSFET Drop)= powersupply DC
DC/1.3=Secondary Vrms
You could experience MOSFET drop closer to 4V but it depends on your VAS drive and or other factors.
Depending on the load and the rectifier Vf I ussually see about 2.5V drop from the unloaded condition. YMMV 😀
I ussually use schottky rectumfriers with about .3-.4Vf @ load.
Ipk*8R0=Vpk
I am thinking with 32V rails, you are real close to 100W unless you have an undersized trafo and overly large smoothing resistors in the PSU
Heatsinks over about 6" tall have diminishing returns. I wouldn't bother going over 8" tall. I think its because the lower part of the sink heats the air traveling up the slots to the point that the upper part of the sink doesn't cool much.
The PCB's are ordered and should be in the store within the month. We got expedited shipping and production.
I know this has been an incredibly long time, but we don't have full time people helping here at the forum or at the store and I have been swamped with work at my "real Job" Also, there were issues with getting the order right with the maker, which is really important !
Ipk*8R0=Vpk
It does not really matter when you do the calculation for Vpk, just so that you do it somewhere.
My guestimate for 5.6 needs some looking at.
A great read, from page 64 and on.
http://www.onsemi.com/pub/Collateral/HB206-D.PDF
- F5 Turbo Builders Thread
