F5 power amplifier
This is my layout and no extra componets added.
resize to 82.8x34.4mm in your printer setup.
massimo said:
Did anybody noticed that in the close up picture in post #926 at the top of this page Nelson added a 2.4 ohms resistor in parallel to the 0.47 ohm source resistor of the Nch mosfet (Q4)?
Moreover, the gate resistor seems to be 150 ohms in lieu of 47 ohms indicated in the published schematics. (Assuming that the left hand resistor close to the gate is R14)
A special tweaking or........???
Who know the answer,please ?
The one and only
Joined 2001
Skorpio said:
2.4R in parallel probertly gives te best balance in current and you might mix the gate resistor with the 150R used for current limiting...
The 2.4 ohm resistor was used to trim for lowest distortion, which I
do if the channel exceeds .005% at 1 watt. As I have said, you need
an analyzer to be able to do this. A minority of channels need this,
and it is random in value and placement.
