F5 power amplifier
My newbishness is going to be exposed in asking this, so please forgive me... but what the heck is all the fuss over this "F5" thing?
What is an F5? I see a lot of talk about it, but I can't gather what it is besides an amp. Is it special?
naah ...... not really ;
catch 22 is in few other things :
- weed is better when dried on high temp heatsink
- it's more pleasant to spend time making amp and later listening da muzak , then fooling around at night
:clown:
> ....There are other FETs with lower Vgs at the same current. Using Fairchild FETs FQP..... will drop a bit over 3V, using Semisouth JFETs hardly anything, using Toshiba 2SK1530-Y about 2.2V, and Toshiba 2SK1530-O (about 1.2V, if you can find them) even less.
So 4V is not holy number. ....
Just to make the information complete, all those FETs have less transconductance than IRFPs, so they won't deliver equal performance as cap-multipliers.
According to my own measurements and not datasheet numbers, the transconductance of the mentioned MOSFETs at 1.3A are :
IRFP250 2.35S
FQA19N20C 2.34S
2SK1530Y 2.14S
And if I am not wrong, IRFP250 has quite a bit higher transconductance than IRFP240.
I vaguely remember Nelson saying that one could replace 2x 240 with one 250.
Unfortunately I no longer use IR FETs, so I cannot verify by actual measurements.
But I am sure Nelson could confirm these numbers.
Most of the measurements have already been published here in this thread, rather at the beginning a few years back.
Best regards,
Patrick
A slight correction to the above (and my apologies). The values quoted included a 0R22 source resistor as the measurements were done for the F5X.
With 0R source resistor, again at 1.3A :
IRFP250 4.78S
FQA19N20C 4.77S
2SK1530Y 3.11S
The only old (2003) record I can find for IRFP240 is 3.2S at 1.3A.
But the data is probably not very accurate with only 6 measurement points, where as the rest has 1000.
Note that these were all measured with Vds = 24V, and a constant case temperature (steady state on heatsink) at 55°C.
Patrick
To be fair to Juma he did say nothing wrong.
4.78S is larger than 4.77S, and 3.2S is larger than 3.11S.
Also the performance would never be equal, if only for the simple fact that the dropout voltage is lower.
People who tried both also knows that Toshiba's has a "faster" sound, and you can look at the follower pass device almost as a cascode.
But I agree it is better to put facts on the table than to make simple rhetorical statements.
Patrick
Finally I've made a start:
