F5 pcb group buy...
Sent payment for two stereo sets. I was a little confused where to post, there are 4 threads for the F5 boards. Must say it's really popular 🙂
Edit: Is anyone using the tech-diy.com parts kit with these, how are the vertical Ohmite 4.7 ohm resistors fitting on it? Do we need to have some kind of wire jumpers?
I orignally bought the tech-diy kit for CViller's board which fit well. But for Peter's board, the parts would fit, but you would have to mount most, if not all the resistors vertically, so it's up to you. If you take out the current limiting circuit, there aren't that many parts anyways. But Jack is a great guy, he even had me send in my bad F5 build to check out. I buy all my FET's from him.
Thanks. I needed to have a board with the active devices on opposite sides (individual heatsinks). Both cViller and the suds (the latter available locally) had the devices on the same side. I have no problem with vertical resistors, actually.
I already have the parts from Jack 🙂
