F5 Listening Impressions & Discussion
No, same ~1.3A through each mosfet.
Here's a note I snipped about using the Toshiba 2SJ201 and 2SK1530, NP post 6408:
"Judging by the curves on those parts, when paralleling them
you can raise the Source resistor to 1 ohm and get greater
thermal stability yet."
Actually this thread may not be the best place for this Q, so I will prob bring it up later in cviller's F5 blog...
PS. Legalize it!
PS. Legalize it!
Please do .... .. opps , i mean Cvilliers F5 blog 😱
PS. Legalize it!
Well if you adjust the bias you can set it anywhere pretty much with any reasonable value of resistor in the hole... but if you keep the bias setting the same and raise the R value... or made the total current the same 1.3amps no matter what then the amp still runs the same amount in class A into the same load. Or so it would appear...
...and the question in my mind is do you want/need better thermal stability or do you want a lower value resistor for sonic reasons?
PS. Legalize it!
These words from Nelson have to be situated into the context when they have been said:
The question was about my tweeters dc coupled to the amp. A tiny offset was wished stable in this case. So the 1 0hm source resistors have been suggested.
At least, i think so.
I use Toshiba outputs, sound wonderful, and w/o tempco they are very DC stable.
I think they are a bit more detailed than Nationals, while not sounding peaky or rough. They are smooth and refined. I use .47r, but lowered R3 and R4 to 1K to get a little more 'action' out of the 5K pot. They otherwise bias up very quickly.
The blasphemous method to assure absolute minimum DC offset is the <gasp> dreaded DC servo circuit.
The question is where and how to apply such absurdity - if one was to do that.
Dunno, but maybe the idea I came up with back in post - oops in the F5 thread - I think, to use the current limiting transistor for something else, to control the bias via the thermistor. Which means that it could replace the trimmer pots. Which means it could maybe, perhaps get a voltage back around from a DC servo sensor to set the offset to nil??
But, as I said "that's a different amp"...
_-_-bear
Hi Tea-Bag,
glad to hear that your listening impressions with the Toshiba MOSFETs are the same as mine 🙂.
Regards, Uwe
Fwiw, my batch of Toshiba "K"s has just arrived... the "J201"s are not far behind. I will be matching them using my Tek curve tracer. I expect to get a few good quads out of it and a number of duals. I'll also sell "best pair" N & Pch singles... the quads of course are optimum for the Cviller 2 Mosfets per rail boards, although not essential since the bias can be set for each rail independently...
I figure about 2 weeks to slog through the batch and see what is what... the J's will not be in my hands until midweek...
When i am all set i will put a post up and link from these F5 threads...
If there is no demand, I'll just keep 'em around... 😀
_-_-bear
