blackdod Spain 2
BMF USA 2
ripson UK 2
hipcheck USA 1
Ryssen Sweden 1
Dennis Hui Canada 1
RollE2k Sweden 1
pchw USA 1
Xen team internal 2
Running total 13
2x Version 2 left.
Patrick
BMF USA 2
ripson UK 2
hipcheck USA 1
Ryssen Sweden 1
Dennis Hui Canada 1
RollE2k Sweden 1
pchw USA 1
Xen team internal 2
Running total 13
2x Version 2 left.
Patrick
My fault, not getting the DAO and the F5XP ready soon enough .....
blackdod Spain 2
BMF USA 2
ripson UK 2
hipcheck USA 1
Ryssen Sweden 1
Dennis Hui Canada 1
RollE2k Sweden 1
pchw USA 1
Xen team internal 2
CeeVee Portugal 1
Running total 14
Patrick
blackdod Spain 2
BMF USA 2
ripson UK 2
hipcheck USA 1
Ryssen Sweden 1
Dennis Hui Canada 1
RollE2k Sweden 1
pchw USA 1
Xen team internal 2
CeeVee Portugal 1
Running total 14
Patrick
blackdod Spain 2
BMF USA 2
ripson UK 2
hipcheck USA 1
Ryssen Sweden 1
Dennis Hui Canada 1
RollE2k Sweden 1
pchw USA 1
Xen team internal 2
CeeVee Portugal 1
Running total 14
Patrick
To quote someone i respect imensely " good things are worth waiting for "....😀
So finally some progress.
I have now a commitment from HK that the V1 PCB sets for s610adam & greyhorse can be shipped first half of April.
Our apologies for the delay.
Mark will invoice you beforehand, when he is ready.
The V2 Beta test boards will also be shipped around the same time, to 2 Beta testers.
So hopefully we can still keep the July schedule for finishing the tests.
The fully differential F5X-HA will also have the Alpha PCBs ready in a couple of weeks.
Thank you for your patience,
Patrick
Patrick
Patrick, thought i would ask - do you think the crossfeed gives big image difference?
When you will do F5X-HA, how does one implement it then? Same way but 2x (one between positive phases, and one between negative)? Or are you going to skip it on those boards?
Also, will the F5X-HA be sold just as plain boards, or will you be offering PSU-boards, crossfeed-boards and so on at the same time?
> do you think the cross feed gives big image difference?
One of the first V1 builders said, "...Before using the crossfeed, I can hardly stand hearing for more than 1 hour.
Now I can easily do 3-4 hours. So much thanks to you for this....."
A fully balanced version. New PCB layout, in 2 separate boards.
The F5X-HA is a more complicated project like the DAO SE.
It has many small boards, each with its own functionality.
The advantage of modularity is unlimited options and easy upgradability.
The disadvantage is the need to plan layout as well as wiring.
The boards are now with the Alpha tester.
He is allowed to take as long as he needs.
The important thing is to get it right.
So no rush.
When it is ready, you will get to see all details.
Whether it will become a public project depends on how much interest.
There have been e.g not much interest with the XEN ZGF, which is a pity.
I am enjoying it every time I am travelling on the train.
And that is at least 8 hours a week.
Patrick
So no rush.
Patrick
What i meant with the above was, how does one implent the x-feed on balanced?
Is it just two x-feed circuits with one between both positive phases, and one between both negative? or is it something even more complex?
Essentially.
Patrick
Essentially.
Patrick
Patrick: Is the BC807/817 replaceable with BC327/337? not considering one is SMD other is to92, plus different pinout.
Great, i got 327/337 (even hfe matched) at home already. So will go for them!
Almost finised designing single channel pcb's to fit at the side sinks of the chassis instead.
Yes, you can do so.
I'll maybe later be interested in F5X-HA when you are finished with them. But right now i try to keep budget a bit lower (otherwise i have to buy another DAC also).
blackdod Spain 2
BMF USA 2
ripson UK 2
hipcheck USA 1
Ryssen Sweden 1
Dennis Hui Canada 1
pchw USA 1
Xen team internal 2
CeeVee Portugal 1
Running total 13
Patrick
BMF USA 2
ripson UK 2
hipcheck USA 1
Ryssen Sweden 1
Dennis Hui Canada 1
pchw USA 1
Xen team internal 2
CeeVee Portugal 1
Running total 13
Patrick
My guys in HK just told me that they can ship the V1 PCB sets next week.
s610adam & greyhorse please kindly keep an eye on Paypal invoices.
Our apologies for the terrible delay ......
Patrick
Patrick
Schematics of the cap multipliers attached. I am using a string of two LM329 and two red Led's in my build to arrive at 16.4V.
The transformer is a custom wound toroid with two shields and 2x18.5V, so plenty of overhead. No mechanical hum, no noise.
Sinks of the supplies are temporary of course, didn't have anything better at hand 😉 Final wiring will also be nice and tidy.
I decided to build the f5hp. 2107 case has been ordered, I will sacrifice a set of sk170BL/sj74BL, which seem to be worth their weight in gold for this project. I am going to order 20 or so fairchild mosfets and hope for the best in matching. I will use veroboard for the build. Headphones are AKG 272 (at work) and Grado 125. Hope to purchse a set of K701 or K702 soon. I really like AKGs. I listen two a dual pair mosfet F5 at home, so I am familiar with the topology.
I am putting together my parts order...I will use Stixx's regulator/cap multiplier.
Stixx: In the original schematic you posted you show an 8.2R resistor between the power caps which form a CRC filter. In the schematic on your website you are showing a single cap, no CRC. Any preference here? I will use a 18V transformer.
- F5 Headamp ?
