F5 Amps - Building a Quartet of Amps in search of the Ultimate F5
NYCOne
2010-07-13 6:27 pm
I've decided to post all my builds in one place going forward.
A few months ago I came to the conclusion the F5 amp was the most accessible amp for my purposes. As I learned more and more about Class A and Pass Labs, I wanted to try to build my own F5. I'm a scientist by training, and in reading the F5 thread, I became interested in the various permutations of the F5 that seemed obvious. These include the Cascoded F5, the Balanced "X"ed F5, the Standard F5 with multiple outputs.
I was a little surprised at the relatively small amount of information available on some of the designs. While folks were clearly building these amps, only small bits of information have come to the Forum for a few of the efforts. I tried to encourage better flow of information around some of these designs to better understand them myself and have a successful build.
My efforts to date have shown me building these amps is relatively straightforward. They hold only a few surprises, and I have embarked to build as many of them as feasible to try to help myself understand their benefits, and also to help anyone else that asked. I am a neophyte in this domain. Every time I pick up a soldering iron I learn something new. I've had lots of help from other forum members, and could not have gotten this far without J, TB, ZM and NP.
Over the next few weeks, I hope to post side by side impressions of my:
  1. Standard F5
  2. Cascoded F5
  3. Balanced F5 with IRFP outputs
  4. Balanced F5 with Toshiba outputs
  5. Balanced - Cascoded F5 with IRFP and then Toshiba outputs
These are actually four different builds (thus the title of the thread), even though there are more than four permutations of what can be done with these builds.
I'm happy to answer any question I can, to try any experiment I can, and post everything I do, whether it works or not. I've already had a warm welcome via PM with folks who've asked for PCB layouts, advice, etc.
I post as fast as I can - sometimes it will be daily, other times I might go days without a new post.
I'm not an "expert" and I hope to never become one. I'm an average guy interested in technology, trying to get the most out of my DIY audio budget.
Russellc
2003-03-06 12:59 am
midwest
  1. Standard F5
  2. Cascoded F5
Your straight forward efforts are greatly appreciated. I am preparing in the next couple of weeks to make an order of 2 pairs of heat sinks from M&M metals, and plan on building at least 2 of your versions.
will all of your builds be utilizing the same size heatsink? I dont know if the usual 12 x 6.5 inches with 2.3 inch fins that I have been using would be adequate for the balanced or multiple output versions?
Also, on your cascoded version, will you be upping the PS rails, or standard 18 + 18 transformer? You are further up the learning curve than I am, but I thought the purpose of the cascode (and please feel free to correct) is less distortion, but also some great advantage with increasing the rail voltage for increased power? I got this notion in an exchange concerning a cascoded, increased rail voltage BA-2, which I want to build, but I am not ready for that. Hopefully by the time I get the next F-5s built I will be ready. A normal BA-2 would be built first.
In the mean time, I want to construct a "Mule" chassis with power supply adequate for several Pass power amp builds, which should facilitate my small efforts.
Thanks for any info,
Russellc
6L6
Moderator
2010-10-22 6:43 pm
Denver, Colorado
I have a sneaky suspicion that I will be building another F5 fairly soon... (for a friend) Dual transformers and Toshiba outputs, as well as fancy-pants audiophile resistors and power caps. I am very interested in other bits and pieces as well.
Looking forward to hearing about your observations of the various builds!
Ummm... you'd better build a few versions of the base version F5 first!
Looking back at the thread on how changes, including just parts changes, to the base version altered the sound, you'd do well to establish a baseline before delving into other versions as what you find may or may not correlate back to the circuit quite so directly.
Experiments done by a good friend locally, with some help from myself, showed that the F5 is not exactly "one" amplifier with "one" sound. It varies rather quite a lot all over the map depending on things as simple as bias levels, and power supply implementation. Not to mention those pesky parts... :D
I started a thread last year on just this topic... it's still out there... I think it is...
_-_-bear
NYCOne
2010-07-13 6:27 pm
First, I want to say thanks to all the folks who've PMed me over the last few months in support of my efforts - I really appreciate the kind words and sympathy for my frustrations. I have to say again, I would have given up had it not been for NP giving me some simple, but key information along the way. He knows more than any one else on the forum, and he's a real gentleman about teaching. A very classy fellow.
Next, apologies for the delay in my response - my day job has gotten quite busy of late.
To answer some questions:
Heatsinks:
All my builds are designed to use the Conrad MF35-151.5. There's not a lot of reason for this except I bought a pair, and want to use them. I drilled each with four holes to accept four output Mosfets for a total of eight on the two heatsinks. In retrospect, if I were starting again, I'd go for something bigger from HeatsinkUSA. I was thinking four 10"x8". Rough cut, it would double my heatsink capacity.
Juma's F5:
I agree, I'd like to include Juma's F5, I considered building it, but I had to draw the line somewhere, and to buy those outputs would be another $50 or $75 (I forget the exact number). If someone has a set and is in the NYC area, please come over and we can try them out. When I narrow down my efforts, perhaps I'll sell something and get a set.
PCBs:
Yes, I etch my own boards and YOU SHOULD TOO! It's so easy, and it lets you try anything and everything. I'd never etched a board in my life until about 2 months ago. I'll only buy a board if it's more than two layers, two layers is my home limit. I use the toner transfer method. I found great Staples paper that makes toner transfer a few minute issue. I buy PCB literally by the pound on eBay. I etch with HCl and H2O2. My all in cost per board is ~$2-3. I go from idea, to layout, to transfer, to etch and drill in about 2-3 hours total.
Transformers:
I'm going to be buying new transformers. Right now I only have 2x18V and 2x26V. I haven't come to a final decision, but I'm leaning toward 2x12V or 15V for the Balanced Circuit, and 2x24 or 26V (if I do 26V I'll need a larger VA rating than I have with my current tester toroid).
"Fancy pants" resistors:
I bought the Futaba MPC74 resistors. They are nearly impossible to get in the US at any reasonable price. In the EU, they're sold in Germany by a retailer. Do not buy from eBay, I believe the seller is selling counterfeits. Why these resistors? They're 5W, non-inductive, accurate metal plate resistors in the right, weird values needed for the Balanced F5. I bought a LOAD of them. I have more sets than I can use, if you want a set for your build, let me know. I also have hundreds of 2SK170BL and 2SJ74BL matched.
Evaluation of the F5s:
Finally, I'm pushing the build of my Martin King OB speakers - FF85K over Alpha 15s. I fired up the router (first time ever using one) tonight, and made a circle jig. I hope to do the cut outs over the weekend. Once I have these, I should be able to really test the amps.
On another note, I've said it before, I live right in the middle of Manhattan, if you're coming to NYC for work of fun, please feel free to stop in and see the efforts first hand.
Please don't forget my call to arms: Build! You can't go wrong - these are wonderful amps with forgiving designs. Build!
Russellc
2003-03-06 12:59 am
midwest
Heatsinks:
Juma's F5:
PCBs:
Transformers:
Thanks for the encouragement on board making. I will research what you have posted before asking any more. I would be interested in your layout if possible. If so, I will PM an Email addy. I've waited way to long to do this, and this is where I'm going to start. I'll check Ebay for the board source and see if I can locate the other chemicals locally here in KC.
Thanks for the info by the way, your thread is really pushing my DIY envelope, and it needs pushed. Once I get this down, I'll post a mini tutorial on it, assuming I'm successful!
Russellc
NYCOne
2010-07-13 6:27 pm
Small updates
Bias Current:
I think I figured out my error in biasing. I'd been confusing bias current with peak current.
So if I understand this correctly now, when I biased the Cascoded F5 to .6V (with a 0R47 source resistor), I was at 1.3A bias and 2.6A peak. Straightforward, right?
I guess I'm a little hazy on the Balanced F5. There if I bias to .22V (with a 0r22 source resistor), I'm at 1A bias and 2A peak again, right?
Parts for Balanced F5:
A few folks have asked me about 2SJ74s, Futaba resistors, PCBs, etc. I was thinking of putting together a kit which would include:
8 matched front end transistors (with or without degeneration matching - four 2SK170BL and four 2SJ74BL)
8 BC546 and BC556 transistors
8 Futaba resistors for the Mosfet sources (four 0R22 and four 0R18)
A piece of 2oz Copper PCB
A few sheets of Staples toner transfer paper
A file with the Balanced F5 and the Balanced Cascoded F5 layouts (I could print this on the Staples paper if it's helpful)
None of these items are particularly difficult to obtain on their own, but they have a "Pain in the neck" factor to them. Some more than others. I thought a kit could accelerate builds for folks. All that would be left would be buying matched output transistors (I got mine from ZhouFang), and the routine resistors for the PCB. I guess I could also offer these items minus the PCB stuff for folks using stock F5 boards for their builds.
Let me know if there's interest. If so, I'll price something out and PM people back.
NYCOne
2010-07-13 6:27 pm
Bear,
I've been running cutting edge scientific experiments for more than 30 years. I'll test the amps according to well known principles:
Same and differing power supplies
Same and differing bias settings
Same and differing outputs
Same and differing resistors
Well, you get the idea. I have no doubt the Stock F5 can sound differently under differing circumstances. Hopefully, I can isolate the differences and come up with an optimal outcome.
_-_-bear
ra7
2009-02-07 6:47 am
Davis, CA
More on PCB building please... I mean info on what YOU use, not some internet article.
1. where do you get parts (links) - PCBs, etchant, drill bits.
2. Step by step procedure - well, this is simple enough but put it down anyway :) ... especially the part about drilling those pesky holes. You seem to be doing it faster than anybody I know.
3. Software used for PCB design
I know this is a lot to ask, but you've done so much that this info really should be in here somewhere.
Tea-Bag
2006-02-08 2:32 am
Kennebunk
Sounds like a perfect blog article.
NYCOne
2010-07-13 6:27 pm
Prospective Excellent Value for Power Supplies
Another forum member is selling 68000uF 75V caps for $10 each, he'll pay shipping of you buy 6 or more. This is an excellent value. I tracked down the original price for these caps - it was over $110 each.
I like this item for lots of reasons, but especially one can use the PS for a Stock, Balanced or Cascoded F5 because of the 75V rating. I have 50V rated caps now, and had to limit my choice of transformers for the Cascoded amp - not anymore.
Four of these would make a nice PS for most Pass amps.
Nelson Pass
The one and only
2001-03-29 12:38 am
I have pretty much gone through the permutations listed,
and it's a worthy progression.
In the end, it is probable that you will settle on cascoded
2SJ109's and 2Sk389's driving Toshiba's biased as high
as you dare. Get yourself lots of heat sinking and power
supply capacitors, and use bipolars for the cascodes.
In this circuit, balanced mostly brings more power to the
table.
Minimize the feedback where you can.
The journey's the thing. If you just skip to that, you'll
miss out on some cool stuff.
:cool:
